Author Topic: help? av got a robot noise under front of car?  (Read 1933 times)
chris b
« on: 12 February 2007, 17:57:10 »
hi chaps. i have a small prob? when startin my 3.0 elite up in the morning it makes a wiinding roboty noise just under the front bumber passenger side ? eny ideas? it only lasts about a minute and then go`s :-X
Re: help? av got a robot noise under front of car?
« Reply #1 on: 12 February 2007, 17:58:29 »
2.0/2.5/3.0 engine?
Secondary air injection pump. Unplug it. Not reqd.
chris b
« Reply #2 on: 12 February 2007, 18:04:37 »
 the noise cums and go`s m8 . what does it do tho? :y
« Reply #3 on: 12 February 2007, 18:09:01 »
It only runs for a min or so when engine cold. Its an emissions device, and pumps air into exhaust which heats cats up quicker.  As said, it can be safely disconnected.
chris b
« Reply #4 on: 12 February 2007, 18:13:53 »
thanks for your help m8 will do. :y
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #5 on: 12 February 2007, 21:47:46 »
Is there any advantage if you disconnect it?
« Reply #6 on: 12 February 2007, 21:56:29 »
Yes, it doesn't make the noise!  :P
« Reply #7 on: 13 February 2007, 03:44:35 »
Heh!
Don't you also need to plug the Air injection pipes too?
*looks for an AA battery....*
« Reply #8 on: 13 February 2007, 08:13:51 »
That is an option but, not neccassary if the one way valve is working.....
