Steering Idler
Started by old cruiser, 14 February 2007, 19:36:44
No....you need to test them seperately....
Your looking at the idler to observe the movement...
bestseany
QuoteVague steering and random driving/pulling to random sides - felt like steering wheel was not properly attached!!
Steering is tight as fook now, not only do I get my car back after being written off, I get a horrible problem sorted... Part was about £40 all in from Mark @ Autovaux
Ah, right, that sounds similar to my problems then. At least I've got another possible solution now.
My week off work is going to be busy next week....  ::)
sophos9
Another thing I failed to mention were the intermittent strange vibes through the steering wheel at about 1:30 and 10:30, this has all been resolved now....!
Mark, after having the arm replaced will I have to have a tracking check? If not is there a danger that the tracking may have been set incorrectly due to play in the passenger wheel?
Cheers
QuoteAnother thing I failed to mention were the intermittent strange vibes through the steering wheel at about 1:30 and 10:30, this has all been resolved now....!
Cheers
Always worth checking geometry after any suspension/steering work.
However, I would strongly recommend a full geometry check rather than simple tracking...
Idler would only affect the tarcking and any change would most likely be un-measureable
sophos9
#20
Will get the tracking checked....Last year I had 2 full geometry set-ups, the first they neglected to notice I had buggered shocks all round, the second was much after I fitted new suspension all round.
Dam expensive getting these done every year!
