Author Topic: That brick wall still.  (Read 1720 times)
Kes
« on: 17 February 2007, 14:31:49 »
A while ago i posted on the hitting a brick wall at 3400rpm but only when engine is up to temp .
I have only changed the can sensor which came to no avail .
Next month its going to a mech mate to do the rocker gaskets oil n breather, ht leads .
Some one spoke about the multi ram valves with a piccy of their rpm cycle .
The front ram I can see opening just afore the brick wall but I can't see the rear one operate at the same time , is it supposed to or does it come at a diff rpm . Even if I pull on the link arm of the valve to open it the car will still not rev past the wall . Could this be a problem if so do I change the whole ram or is their a solenoid somewhere  :(
« Last Edit: 17 February 2007, 14:51:38 by Kes »
Re: That brick wall still.
« Reply #1 on: 17 February 2007, 16:43:31 »
When was the fuel filter last changed?
Kes
« Reply #2 on: 17 February 2007, 18:25:22 »
Pass , not since I've owned it 9mths . Worth doing at the same time then .
