Major water loss
Started by cornishtaz, 17 February 2007, 17:17:50
cornishtaz
Found the problem, the hose that goes from the block to the bottom of the HBV has a 1cm split in it. Max is kindly going to collect some spares from Henry for me.
Markjay
...another Omega with a healthy head gasket then  ;D
Alas, no more Omegas....
cornishtaz
It was easy to spot once I got the rain scuttle out the way but what a bugger to get out as it had one of those spring type hose clips on it which you couldn't get the pliers too ended up having to slowly and carefully lever it off.
Will be using the screw type hose clip when I refit it.
The culprit
sir moanalot
well done mate a bit of a relief for ya.
these jobs done by other people certainly help out a lot !
MaxV6
Parts Collected and awaiting your pleasure sir.....
Glad to be of service.
Max
cornishtaz
QuoteParts Collected and awaiting your pleasure sir.....
Max
Cheers mate will see you tomorrow
Not uncommon for that one to fail...
MaxV6
well I have a complete set of all of them.....  in addition to the one for CornishTaz's  :D
any takers on the odds of both our coolant pipe failures being the same pipe?
Quotewell I have a complete set of all of them.....  in addition to the one for CornishTaz's  :D
Highly possible.  Failing that, the throttle body warming one that goes round there...
cornishtaz
Well the Omega lives on
Thanks to Henry for the parts
Thanks to Max for collecting them and nice to meet you
MaxV6
Likewise mate... Glad to have helped out.
QuoteLikewise mate... Glad to have helped out.
You got your coolant leak sorted then?
MaxV6
No, That's happening tomorrow. "need smiley for Crossed fingers and a hopeful demeanour"
I have been running about in the 106 for a week.....  it's just desserts really for taking the piss out of the Rover......
needless to say that I'm going to take the long way home on Saturday night :D , give it something of a "shake down" run.
As I'm about and sober, I could probably do a couple of taxi runs to hotels at the end of the day.......
