98 elite satnav upgrade ??
Started by jud1255, 15 February 2007, 21:24:12
Dave-C
Yeah, this is the one.. DC
QuoteDon't quote me, but I thought the Carin one needed a system software update to do postcodes...
In my instance, I have a totally standard Phillips CARiN, it came with the original SatNav disc which only had the midlands!! The disc is the limiting factor here...
I believe this is the disc but please email the seller first!
This is the version info from my CARiN
HW-ID 1005
SW-ID 1500
Hope it helps  :y
sophos9
Please check you hardware and software version
HW-ID 1005
SW-ID 1500
jud1255
mine is
Ident No 581/75
HW id   0105
SW id 0230
Product date 98 / 04
sophos9
and can you search via postcode.... You have a better software version than me  >:(
jud1255
no i cannot search via post code also i cannot search via street first .I have to select city first which is why i wanna upgrade.
Im just gonna buy ebay item No 200074139023 he just emailed me to say "yes , still got some here, £15 plus £4.75 next day delivery" i understand from dave c itll work on my 98 elite
sophos9
Checked that item.... 110% working backups on CDR ;)
Please post up when you get it and see if it does postcode (mine does it fine)
QuoteChecked that item.... 110% working backups on CDR ;)
Mine won't let me put all of the post code in.
If the post code was AB1 2CD it would let you get as far as AB1 2.. then it'd ask you for the street name. My disc is a *coughs* of a 2004 disc!  ::)
sophos9
:D
Whats your hardware and software version?
:D
Err? The disc is 2003/1 ...... and that's all I know. What do I press to tell you more?  :-/
jud1255
sophos 9
will let you know in a few days although you may have to pm me to remind me, you know what its like or maybe not ha ha.
yeh fingers crossed as itll make it a lot easier to use .
:D
Found it!  :)
Ident No     SY582/7
HW-ID        0203
SW-ID        0230
Prod Date   99/07
Who can remember what the code is to get into service? I've been there before but can't remember the code now. I'd like to have a play with the disc that allows you to change the voice.
sophos9
Dave-C
Is there a programme disc for these systems then?  I'm really interested in this topic! :P
sophos9
Software upgrades are via a special CD... One which I have not been able to get hold off!!
ANYBODY  :o
markrl
Just browsing through and thought I'd comment on a few points raised. First of all full postcode searches are not possible with the GM Carin system, only partial searches as pointed out above, provided you have a mapping disk that supports it (I think 2002 and later if I remember correctly).  As for upgrading the firmware the standard GM fit systems used a firmware version that was unique to GM so you would need a GM upgrade disk. The standard Carin firmware disc would not work. I think the latest version of the firmware is 2.3. This was at one time available from Vauxhall along with language discs. I did find a firmware disc by accident at my local dealer's parts department who had no idea what it was and thought it was a mapping disc. Vauxhall switched to a different Sat Nav system in 1999. Sadly much of the information regarding Carin has now disappeared from the internet although there is still some useful stuff in German. ;)
