Author Topic: Auto Box ECU upgrade  (Read 7237 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« on: 07 February 2007, 19:56:26 »
Having seen this mentioned on a few occasions, can it be done to my 96 (PReg) TD Estate?
If how & who, or is it not relevant to what you guys refer to as 'Tractors'?
What are the benefits from such an uprade?
Re: Auto Box ECU upgrade
« Reply #1 on: 07 February 2007, 19:59:51 »
The benefits in the software upgrade in the ECU are a much smoother change, and apparently less 'slip' in the box.  Huge difference.
Your local dealer scumbag or me are the peeps to talk to...
Irrelevent as far as you are concerned, as pre 98 cars do not have updatable firmware on g/box...
« Last Edit: 07 February 2007, 20:00:44 by TheBoy »
SteveD
  • Blackpool (no casino)
« Reply #2 on: 08 February 2007, 22:27:40 »
Is there a way of checking what version you have without tech2? Something like sticking a finger in the cigar lighter while holding sports button with your nose and operating the bonnet alarm switch with your foot?
I'm sure I've seen something about how to tell... or maybe I was dreaming  :o
Markjay
  • London
« Reply #3 on: 08 February 2007, 23:25:18 »
...Something like sticking a finger in the cigar lighter while holding sports button with your nose and operating the bonnet alarm switch with your foot?...
Yep - that's the one!  ;D
Alas, no more Omegas....
« Reply #4 on: 09 February 2007, 07:40:51 »
Unless yours has been updated at some point (unlikely), you ain't got the smoother one.
Only way to get specific version is real Tech2 or cheapo one if its in a good mood at the time...
« Reply #5 on: 09 February 2007, 07:58:49 »
As the boxes are apparently mechanically the same, is it possible to get just a later ECU and flash it with the revised software?
« Reply #6 on: 09 February 2007, 08:14:21 »
dunno, probably...
« Reply #7 on: 09 February 2007, 08:17:24 »
dunno, probably...
Righto,
When I get the new car sorted, I'll hunt about for a later ECU, and we'll Tech2 it and find out? ;D
old cruiser
  • Slough
« Reply #8 on: 09 February 2007, 13:49:20 »
Mines a 2.2 ,2001 reg. does anyone know if this is likely to have the latest software upgrade for the gearbox?
cheers Pete
« Reply #9 on: 09 February 2007, 13:54:22 »
cheers Pete
Its likely it doesn't have the latest...
« Reply #10 on: 09 February 2007, 15:05:21 »
cheers Pete
My dads 2001 2.2 CD had autobox software V1.0... and V10.0 is the latest!  :o
« Reply #11 on: 09 February 2007, 15:09:29 »
cheers Pete
I think it was V9 I put on. May have been V10, can't remember what ECU it was GX820 or GX821...
« Reply #12 on: 09 February 2007, 15:11:30 »
And as I did it for nought, I expect a full report on it to be posted in the forum ;)
Taxi_Driver
« Reply #13 on: 09 February 2007, 19:01:52 »
How does it make it change smoother?
I assume it tells the engine ecu to retard the ignition at the point of change....to make it smoother....and something the earlier versions didnt do?  :-/ Or this only possible on facelifts/coil pack ignition setup?
Drove my merc today.....now that is a smooth gearbox.....far smoother than my omega....drive it normally and you carnt even feel the gear changes....you only know its changed gear by watching the rev counter! ....Something merc is good at! autoboxes! Crap at manuals tho!
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #14 on: 09 February 2007, 19:36:50 »
I checked mine I've got version 5 - so mines way behind !!!!    :-/
It's 1999 so could be upgraded ?
« Last Edit: 09 February 2007, 19:39:47 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
