Author Topic: Can I retrofit Cruise control to my car??  (Read 6615 times)
2.2dti
  • North West
« on: 08 February 2007, 22:40:37 »
Hi All,
New to this I have had a bit of a browse fround the site so I dont ask a silly question that has already been dealt with elsewhere...I can only see references to retrofitting cruise cont on auto cars...
Can I retrofit cruise control on my '02 plate 2.2dti manual?? I had cruise control on my '98 vec GSI manual so I know vaux do it but did they ever do it on the manual omega?? also can you retrofit traction control to these beasts??
Many thanks to anyboy with any info for me !! :)
Re: Can I retrofit Cruise control to my car??
« Reply #1 on: 09 February 2007, 07:44:27 »
Hi All,
Cruise yes (stalk needed, possibly clutch switch (look for it) and a chat with a tech2).  I believe its the 4 wire stalk reqd for dti, but would have to check.
TC, no.
jonathanh
  • coventry
« Reply #2 on: 09 February 2007, 07:54:01 »
You are unlikely to have a clutch switch fitted (£22 from dealer) as TB says have a nosey around to see if you have it fitted.
When you are there, check if you have 4 way brake switch, I think you need one of those as well (although my knowledge of the 2.2dti is very limited).  The only way of checking is pulling the multiplug off and checking that you have 4 terminals.
« Reply #3 on: 09 February 2007, 08:13:21 »
Generally, it seems the 2.2 petrols had the clutch switch, 2.6/3.2 don't.  All facelifts I've seen have 4 pin brake switch...
jonathanh
  • coventry
« Reply #4 on: 09 February 2007, 09:02:24 »
It will be interesting to see if the clutch switch is on the 2.2dti as standard.  I didn't know about the 4 pin switch on the facelifts!
« Reply #5 on: 09 February 2007, 09:13:12 »
Hi All,
TC, no.
I think its 2 wires for diesels, I know I always confuse them. Picked up a stalk for my dads 2.2 petrol and it has 4 wires.
« Reply #6 on: 09 February 2007, 09:36:31 »
I don't ;)
« Reply #7 on: 09 February 2007, 09:40:53 »
2.2dti uses part number 9181011 - 4 wire one...
2.2dti
  • North West
« Reply #8 on: 09 February 2007, 09:49:11 »
Thanks for all the replies!! :)
I will get my head under the dash at the weekend and have a look to see if I have the clutch switch and if I have the 4 wire brake switch fitted...other than that if I just get a stalk and the clutch switch if I need it is it really that simple or do I need some tech 2 electronical jiggery pokery done as well?? :-/
JasonH
« Reply #9 on: 09 February 2007, 09:49:39 »
My facelift didn't have a 4 pin brake switch  :(
« Reply #10 on: 09 February 2007, 09:51:52 »
Sorry, I meant DBW ones. Thanks for correction...
« Reply #11 on: 09 February 2007, 12:21:19 »
I don't ;)
So its only the BMW 2.5 TD which had the 2 wire version?
« Reply #12 on: 09 February 2007, 12:49:25 »
I don't ;)
Yup, rest are all Vauxhall engines, so same stalk...
Martin_1962
« Reply #13 on: 09 February 2007, 13:12:26 »
DBW use the brake signal as a fail over for idle (sort of)
Basically if the throttle pot goes wrong brake will shut off the throttle
old cruiser
  • Slough
« Reply #14 on: 09 February 2007, 13:42:47 »
Once you've fitted the stalk etc. you will need to get it on the tech2 machine (a few kind words to one of the technicians down at your local VX garage and might do it for the price of a drink as they did at my local one) all it does is to enable cruise as the software itself is already there.
Cheers Pete
