A bit thirsty - any ideas?
Started by Martin_1962, 26 February 2007, 23:16:44
Martin_1962
QuoteTheres a buisness opportunity.....do a decent LPG controller....one that monitors MAF and O2 and self learns
Any one know what LPG injectors are like to drive electrically? Are they similar to petrol injectors? (pulse width and coil impedance, etc?)
I wonder if you could drive them with a Megasquirt? //www.megasquirt.info
Quotethey piggyback off the cars ECU
What does this mean? Are they monitoring the injector duration from the car's ECU and then making corresponding changes to fuelling on the gas side?
Yes the car ECU tells the LPG ECU to fire the injector, if you cut power to the LPG ECU or press the button for petrol it fail overs to operate petrol injectors.
Martin_1962
Quotebear in mind that if you have Vx trade club access, O/E plugs are cheaper than you'll get equivalents for at Halfrauds ... or off fleabay for that matter!!
I'll try and blag some discount then - no trade card!
Or hassle Halfords with some NGKs
