Author Topic: Head gasket/Oil cooler..??  (Read 5545 times)
stuart30
Re: Head gasket/Oil cooler..??
« Reply #15 on: 02 March 2007, 16:34:42 »
Note.....the engine must be cold to do a pressure test or you want see where the leak is as it will evaporate......
In which case the garage in question couldnt have done a pressure test as requested or if they did they have done it wrong,certainly worth knowing about cold engine.
Regards the water lose id say maybe 7/8 litres over a 20 mile run.
« Reply #16 on: 02 March 2007, 20:25:21 »
:o the system only holds 9l
Matchless
  • Nottingham
    • A white van
« Reply #17 on: 02 March 2007, 21:43:52 »
Water loss is very high, seems too high to be headgasket, does it boil and force water out of the filler cap? if not it has to be a split hose somewhere.
I would remove the wiper arms and scuttle to get access to the hoses at the back of the engine, refill the system then start it up and have a good look around.
philayl
  • Wirral, Merseyide
« Reply #18 on: 03 March 2007, 13:06:28 »
Have you checked the Heater Bypass Valve, often the cause of sudden coolant loss, and not easy to spot.
RobC_NE
  • North East
  • IMI and VSIB Qualified Auto Electrician
« Reply #19 on: 03 March 2007, 15:11:20 »
just for reference stuart30. the HBV (heater bypass valve) is located behind the engine. will probably have to remove the wiper scuttle to see it. a leak will be signified by staining on the engine and HBV. be warned tho, hbv failure can cause death to the DIS (ignintion) pack if not remedied  :-/
from experience, if the HG has gone i would expect to see some "mayo" in the filler neck and on the dipstick at the least.....  :-X
Saxo, corsa, clit drivers. Before starting on a journey, attach a lit sparkler to the antenna of your car. you drive the thigs like dodgems. for the love of god MAKE IT LOOK THE PART!
