Author Topic: Whining noise  (Read 6747 times)
Redeye
  • Lancashire
Whining noise
« on: 03 March 2007, 06:55:57 »
When I do a sharp turn in my Omega I get a whining noise from the front end which continues for a while after. It's only when I do a sharp turn, does anybody know what this could be? Is it the steering?
DaveL
  • Nr. Cupar, Kingdom of Fife
Re: Whining noise
« Reply #1 on: 03 March 2007, 08:38:40 »
i would suggest checking the oil level in the power steering first. Could be low or the pump giving up :'(
 8-)
DaveL
Dave-C
  • Staffordshire
  • The Old Girl
Re: Whining noise
« Reply #2 on: 03 March 2007, 09:12:16 »
Do you have any leaks underneath?  However slight..
I've got a whine in my Omega, but that's my wife! ;D ;D ;D ;D
DC
« Last Edit: 03 March 2007, 09:12:41 by dave_c »
Redeye
  • Lancashire
Re: Whining noise
« Reply #3 on: 03 March 2007, 09:22:46 »
Is the reservoir the black cylinder with the screw top on the passenger side of the engine? I've looked in there and I can see fluid but it doesn't touch the plunger in the middle of the cap, would a low level cause the whining?
I don't seem to have any leaks, it's clean underneath the car.
lol, I know all about whining wives!  ;D
DaveL
Re: Whining noise
« Reply #4 on: 03 March 2007, 09:43:36 »
It is the black cylinder with the srew top. The plunger in the top is a dip stick. The fluid should be up to a mark on this. Cannot remember if you have the engine running or not when you check this. Best guess is that you check when engine is running.
If not enough fluid in reservoir the nair could be trying to go round the system as well as fluid. Air does not compress well, like if you get air in your braking system, so pump makes a 'singing whining' noise.
Check though for a leak, mine was a jub clip that a garage had replaced but not tightened. Not helpful if you find that the steering goes very heavey all of a sudden. And where do you get ATF in the middle of the night in the Perthshire hills? :-/
 8-)
DaveL
Redeye
  • Lancashire
Re: Whining noise
« Reply #5 on: 03 March 2007, 09:47:54 »
Thanks for that, looks like the level is low then. Can we use any power steering fluid, or is there a special one or any we should avoid?
I'll have a closer look for any leaks too.
Thanks.
Redeye
  • Lancashire
Re: Whining noise
« Reply #6 on: 03 March 2007, 14:50:30 »
Result: Topped it up and the whining has gone.
Must keep my eye on it incase there's a leak.
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Whining noise
« Reply #7 on: 03 March 2007, 14:56:36 »
Result, nice one  :y Which fluid did you use by the way?
Redeye
  • Lancashire
Re: Whining noise
« Reply #8 on: 03 March 2007, 16:14:57 »
I used Halford's Automatic and Power Steering Fluid DIII.
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
Re: Whining noise
« Reply #9 on: 03 March 2007, 19:46:14 »
I've read on here that you should use D3 so reckon you're good with that ;)
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Re: Whining noise
« Reply #10 on: 03 March 2007, 19:54:24 »
I think PS should be Dexron II. Not sure if the 2 can be mixed either.  Vx keep changing the spec of the PS fluid.
Redeye
  • Lancashire
Re: Whining noise
« Reply #11 on: 03 March 2007, 20:00:27 »
Well I read the chart on the shelf and it said that all Omegas use DIII (or D3 if you like) except for Diesels which use the DII (D2).
Re: Whining noise
« Reply #12 on: 03 March 2007, 20:18:29 »
Good old Halfords  >:(
I don't think there is an issue mixing DII and DIII, hopefully someone can confirm.  As DIII is a higher grade than DII, that should be fine if mixing is allowed...
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Whining noise
« Reply #13 on: 03 March 2007, 20:28:13 »
Where's MJ? This could turn into an oil thread........
I like red cars
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Whining noise
« Reply #14 on: 03 March 2007, 22:49:15 »
Shhh  :-X
