Author Topic: Another one with an oil leak...  (Read 1787 times)
r.welfare
  • Newbury, Berkshire
« on: 03 March 2007, 19:15:38 »
I notice a fair few people are suffering oil leaks at the moment...and now I have one!
'95 3.0 Elite as most of you know, has had a new cambelt, tensioner, aux belt and now knock sensor on the LH bank.
When I did the knock sensor last week, I did have to give the alternator a fair few hefty whacks to free it.  So I wonder if the oil leak is related, as it has only happened since I cleared the EML by changing the knock sensor?  Now what's odd here is that I had the plenum off (again! to do the breathers) today and there was no sign of oil in the plug wells.  So maybe cam covers OK - I thought they might have gone now the engine is producing the 'full beans'...
Oil appears to be pooling on the top 'lip' of the front of the sump, to the offside of the crank pulley...I have felt around what I assume (as it's going into the front of the crank) the oil pressure switch, which is soaked, but more oddly the cable is also soaked all the way up to where the cable goes into it's plastic tray in the timing belt cover.
A small amount of oil seems to be dripping down the back near the gearbox as well.  I did a service today with GM Semi-Synth and I noticed the old sump plug was a bit loose, so replaced that and got a new washer, however it seems to me that it's not leaking from the sump plug - it's coming from somewhere higher up.  New oil filter as well but that doesn't appear to be leaking.
Did have a go at cleaning off the engine and bay with Gunk then watching for drips, but I can't seem to see where it is coming from.  There is a strongish smell of hot oil from the engine after a run with a little smoke (sometimes) when the bonnet is opened, so I guess some oil is hitting the manifold or downpipe somewhere.
I'm willing to do the cam cover gaskets, but is the general consensus (given no oil in the plug holes, on the HT leads or the plastic around the plug holes) that's what has gone?  If anyone has any other ideas, let me know!
« Last Edit: 03 March 2007, 19:26:12 by r.welfare »
Re: Another one with an oil leak...
« Reply #1 on: 03 March 2007, 19:19:27 »
The cam covers can fail without filling the plugs up...  ...though the leak could be coming from anywhere...
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #2 on: 05 March 2007, 19:39:16 »
well ... I've done my cam cover gaskets on Friday just gone as I've got a similar kind of leak, left them overnight for the adhesive to cure, to be honest I didn't really notice anything massively wrong with the old ones other than the 'o' rings had gone hard with age (but not brittle). At the weekend I drove from home to a mate's place and back again - about 100 miles ... and there's signs of the oil leak on the bottom of the gearbox where it joins the block as before  :'(
I'm not sure where else to look either, I guess I could replace the cam covers themselves ... but I don't think that's where the leak is coming from ... ????
It does seem to be more of a problem on longer runs than shorter ones, though ... the pipes from the breather box to the plenum looked OK when they were removed for cleaning ...
« Last Edit: 05 March 2007, 19:40:54 by sounds2k »
« Reply #3 on: 06 March 2007, 09:01:05 »
Were they genuine gaskets or pattern rubbish......?
sounds2k
« Reply #4 on: 06 March 2007, 11:15:40 »
original and replacements both Vx ...
