Author Topic: What is this pipe?  (Read 4177 times)
toller
  • Mirfield, West Yorkshire
What is this pipe?
« on: 03 March 2007, 15:23:41 »
Whilst having a poke around today after taking of the plenum i found this small pipe that looks like it's borken off from somewhere, i had a good look but couldn't fnd anywhere that looked like it was missing something
Is it actually supposed to go anywhere and if so where.
Re: What is this pipe?
« Reply #1 on: 03 March 2007, 15:25:40 »
Thats the main vac feed for the multiram etc......comes off the brake servo pipe at the rear left of the engine bay
toller
« Reply #2 on: 03 March 2007, 15:27:25 »
Don't suppose it would have anything to do with my previous post about the dash vents not really working properly would it?
« Reply #3 on: 03 March 2007, 15:44:40 »
Yes it would....it explains it nicely.....needs fixing...
toller
« Reply #4 on: 03 March 2007, 16:56:40 »
Just had another look and the pipe coming off the brake servo does indeed have a  little knobbly bit on it, however it looks a very awkward fit considering there is already another 90 degree bend coming off little more than an inch away.
Just want to verify this is actually where it goes and then i'll have to knock something together to make it stay on
« Reply #5 on: 03 March 2007, 18:17:08 »
Thats the spot......the best you can do is cut a 1 inch length of the small stiff breather pipe off somewhere where it can be spared, drill the broken section out using a drill of the same diameter as the breather pipe then insert the cut section and re-enforce around the outside using epoxy.....I wouldn't put any on the pipe as you insert it as its very easy to clog them up....
Essex_Andy
  • Have a guess?
« Reply #6 on: 03 March 2007, 21:10:15 »
personally I'd rob a servo vacuum pipe from a breakers
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Omegatoy
  • UK
« Reply #7 on: 03 March 2007, 21:16:58 »
just block off the hole where its broken out of , then put a t piece into the other pipe thats shown and connect both to that one ? yes its shared vacuum but i bet it wont make a blind bit of difference !!
Omegatoy
« Last Edit: 03 March 2007, 21:17:27 by Omegatoy »
hotel21
  • The Kingdom of Fife
« Reply #8 on: 03 March 2007, 22:09:28 »
Done a repair on my vacuum system last week.  The inlet to the vac tank had broken and used a piece of brake pipe and epoxy to repair, then filled the hole with silicone sealer.
Works OK, no problems.
Done the same with the pipe at the multiram.
Its like a different car now that everything works as it should.  Just take care to ensure that the holes not blocked.
HtH
B
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #9 on: 04 March 2007, 16:51:23 »
Saw this done a time or two at the Cambelt Party by the "Master of Improvisation"  ;) :y
toller
« Reply #10 on: 04 March 2007, 21:39:07 »
Sorted it today with a small piece of copper pipe and some milliput, everything works as it should now....
... well sort of at least, see my other post about the key fob :(
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #11 on: 07 March 2007, 11:36:17 »
Can someone tell me where this pipe goes exactly?  I've still got the rubber elbow bit coming off of the brake servo pipe but there is nothing plugged into it - I've had to tape it up to get it to idle properly...
Thanks,
Chris.
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Matchless
  • Nottingham
    • A white van
« Reply #12 on: 07 March 2007, 12:18:46 »
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #13 on: 07 March 2007, 12:38:14 »
ClarCE : have a look here http://www.omegaowners.com/forum/YaBB.pl?num=1152565204
Brilliant, Cheers.
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #14 on: 07 March 2007, 18:55:23 »
Sorted, I have heat again!  And it goes properly once more..  :y
