Author Topic: Re: 2.0 Stat  (Read 1499 times)
Re: 2.0 Stat
« on: 08 March 2007, 12:41:32 »
Going to change mine in my lunchbreak, it's about the only time I'll get.
Presume, I can just get a halfrauds one? Or is is a special Vx job integral with the housing?
Matchless
  • Nottingham
    • A white van
Re: 2.0 Stat
« Reply #1 on: 08 March 2007, 13:12:19 »
iirc Halfrauds do stock the 2.0 stat....they will even try to tell you that it fits the V6 as well, it comes complete with the casting. make sure you get a new seal strip with it.
Re: 2.0 Stat
« Reply #2 on: 08 March 2007, 13:19:04 »
Cheers Matchless... where is the stat on the 2.0? At the front behind the top hose?
If it comes with casting, will it be pricey?
Matchless
  • Nottingham
    • A white van
Re: 2.0 Stat
« Reply #3 on: 08 March 2007, 16:47:27 »
Top hose connects to stat housing. Access is a bit tight but do-able.
The stat is a bayonet fit into the housing but Ive not found a source of the stat separate from the housing.
Re: 2.0 Stat
« Reply #4 on: 08 March 2007, 17:32:34 »
I bought one. £25  :'(
Stats were about £4.99 in the day of fiesta OHV ownership  ;D
