Author Topic: Help needed with pad sensor  (Read 5721 times)
Taxi_Driver
« on: 12 March 2007, 14:32:33 »
Where does it plug in to the pads?
Old one has been snapped off and left dangling so i carnt see where it came from
Cheers
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
Re: Help needed with pad sensor
« Reply #1 on: 12 March 2007, 14:33:58 »
it clips into that small hole in the top of the pad - I can't remember off hand whether its the front or back one tho - sorry mate..
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #2 on: 12 March 2007, 14:34:59 »
just checked, back one..
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 12 March 2007, 16:51:12 »
If its been snapped off its stud you will need a new sensor.
Taxi_Driver
« Reply #4 on: 12 March 2007, 16:58:40 »
Thanyou.....I guess you mean the inner pad tho?
Taxi_Driver
« Reply #5 on: 12 March 2007, 17:03:42 »
Ive got a new sensor  :y.....and bet you carnt guess who messed with the pads last  >:(
Tho as old sensor was snapped off and even with new sensor plugged in and left dangling for now.....it must be 'make the circuit' for the mid to complain about the pads.....coz mine isnt complaining
ians
  • Reading
« Reply #6 on: 12 March 2007, 17:32:51 »
TBH I thought the circuit had to be made in order for it NOT to complain.  That's certainly what I recall when I was last messing with them.
I also seem to remember this was one of those jobs where Haynes says something like 'unclip the sensor..'  nigh on impossible on old pads I found.
ians
  • Reading
« Reply #7 on: 12 March 2007, 17:34:52 »
Ah I see what you mean - its plugged into the electrical connector (thought you meant the pad for some reason) - that should make the circuit and turn the warning off I believe.
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #8 on: 12 March 2007, 18:37:14 »
Yes, the inner pad behind the disc, sensor plugs in facing away from you at the top middle of the new pad if I remember correctly..
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #9 on: 12 March 2007, 19:12:32 »
Pad & sensor picture
Pin on sensor fits into brass piece on pad [top :cut out in pad to accommodate
sensor]
*** modified after comments following this post***
« Last Edit: 12 March 2007, 21:39:11 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
« Reply #10 on: 12 March 2007, 19:28:55 »
Yep clips into the inner pad.  <2001 have one each side, later have just one passenger side.
Taxi_Driver
« Reply #11 on: 12 March 2007, 19:32:30 »
So just to clarify.....sorry being a bit dimm now  :-[
In the pic above.....assuming thats the inner pad....the sensor plugs into the hole on the rhs?
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #12 on: 12 March 2007, 19:33:54 »
no, brass looking hole top middle
« Reply #13 on: 12 March 2007, 19:34:19 »
Yes.
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #14 on: 12 March 2007, 19:35:46 »
Yes.
I could be wrong then, oops - I thought you meant right hand side of pad (rhs)..
