Author Topic: My Meggy wont start  (Read 6027 times)
rpont
  • Tadcaster
Re: My Meggy wont start
« Reply #15 on: 13 March 2007, 21:18:17 »
I'd read the codes again now, you might have a 19 if the cable is faulty.
mick beck
  • Boston Lincs
« Reply #16 on: 13 March 2007, 21:22:43 »
The Boy; Thanks mate i intend to do that   :y, but i'll bet they're a bugger to fit at the top end  :exclamation
Will also check if there is a 19 fault code RPont, Thanks mate  :y
« Last Edit: 13 March 2007, 21:28:47 by mick_beck »
« Reply #17 on: 13 March 2007, 21:25:11 »
Easy enough if you reroute cable out to abs unit and then back over (strapping to keep away from exhaust).  The original route is flawed as it is clipped to very hot oil pipes...
