Author Topic: Ronnie projects 13 & 14  (Read 7803 times)
RonaldMcBurger
« on: 11 September 2006, 20:28:57 »
OK, so I wasn't gouing to, but I just had to.
So, project 14. An R-reg 2.5v6 Elite saloon in champagne colour with cream leather, walnut, climate, bose etc etc.
Bodywork very nice condition indeed, virually unblemished. Mechanically, a few issues - hence why I got it.
So, known issues are: Overheating after a run, but not during. central locking not working. Aircon not cold, heater not working. Thats it.
After a brief check yesterday, Mark concluded that the car has had an oil cooler change recently. The clues being soft radiator hoses and a brand new header tank. Plus the radiator full of sludge! So today started the strip down to fix that and took a shortcut by obtaining a known good radiator to exchange for now, later cleaning the dirty one and having a spare.
A highly dangerous fault was discovered also yesterday with the presence of LOTS of petrol around the back o the plenum. Now, I know the rocker gasksets have been done (badly) very recently. Easiest with the inlet manifold removed. Now, I always undo the fuel flexi pipe couplings on the EGR side of the 1-3-5 bank. But others undo the internal fuel rail connectors instead, the problem being that people forget to do them up again, which I suspect is what is wrong here. Coupled with the excess heat problem of this car at present, this could have been fatal. I will be following this up with the alleged mechanic that did that job!
Today basically stripped down ready to change rads tomorrow. Also replaced drivers door central locking solenoid, which fixed the central locking issue.
Tomorrow I will be stripping the top end down to replace the badly fitted rocker gaskets to eliminate the oil leak which is still present. Then radiator change and flush through, follwoed by cambelt, water pump, full service and job done.
Here are some piccies:
CLICK to Enlarge
OK, project 13....
This is the 2000 w-reg wreck.
Managed to reduce the noise of the engine a fair bit. The knocking sound is a cam follwer which is being starved of oil. Multiple problems on this car already solved included DIS pack, multirams, vacuum hoses damaged, breathers totally chocked with rubbish and lack of oil!
Did the breathers again today because the crankase is pressurising still and is only relieved with removing the oil filler cap.
So, tomorrow it is strip the front off again, including the cambelt to access teh oil pressure relief valve which Mark pointed me to. Appoartently could be stuck and needs a simple clean. Be great if it is that simple.
If so, I will restore this car too. It is mega-miles and looks like it has done every one of its 229,000 miles so far. BUT, it is basically ok to start from. Has panel damage, scratches, absolute tip inside, nothing much works yet and it is a shed. However, oddly enough the aircon is perfect!
I'll make a beauty out of this heap yet. It won't be a real beuty, but will be worth a lot more than I paid that's for sure.
Remember this arrived on a truck as a non-runner for parts. Engine sounded awful when I did get it going. banging, farting and throwing oil out as fast as you could put it in.
Other fault to deal with turned out NOT to be a blowing manifold as I suspected, but the air injection pump one way valve had failed (like on my CDX) and was thus letting raw exhaust straight through thus making a rioght racket.
So, replacemnt air injection system on standby for installing on the rebuild of the front end.
There you have it.
« Last Edit: 11 September 2006, 20:33:42 by RonaldMcBurger »
STMO123
Re: Ronnie projects 13 & 14
« Reply #1 on: 11 September 2006, 20:35:40 »
Is that all? ;D
Taxi_Driver
« Reply #2 on: 11 September 2006, 20:43:41 »
Is that all? ;D
Bet a brakelight bulb is blown as well  ;D
Well done Ron  :)
« Reply #3 on: 11 September 2006, 20:48:27 »
Nice lookin motor 3.0 exhausts ???
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 11 September 2006, 21:27:52 »
and project 15........c`mon Ronnie your slowing matey  ;)
Good work fella  :)
RonaldMcBurger
« Reply #5 on: 12 September 2006, 07:55:43 »
No brake lights bulbs blown, but one headlight washer is missing >:(
Yep, they are 3.0 looking exhausts. nice huh?
Few bulbs blown on the climate panel, but they are easy when you have a spare climate panel! :)
I'll probably have to get oild out of the heater matrix now as well, so off with the HBV toady too and a flush through for the matrix.
« Last Edit: 12 September 2006, 07:56:38 by RonaldMcBurger »
« Reply #6 on: 12 September 2006, 08:14:24 »
One headlight washer missing I think I can help you there.
If the one you have is a near side one I will have it making your Omega look uniform  ;D ;D
nixoro
  • Hitchin, Herts
« Reply #7 on: 12 September 2006, 10:04:58 »
Well done Ronnie I knew you couldn't give up the projects with out a fight.  :)
RonaldMcBurger
« Reply #8 on: 12 September 2006, 16:39:37 »
Right, todays progress....
Project 14- The Elite
Stripped out remainder of radiator stuff - pig to get out with those connectors on the passenger side so akward to reach (I have the scars to prove!). Anyway, with the old radiator out I continued the strip down taking off the plenum. This proved harder than usual because the throttle cable absolutely will not come off. Don't worry, I know how I've done enough of them, this one will not come off full stop. So, break the throttle bodies off once the plenum is lifted a bit and its a good'un.
Looking deeper to find this mystery petrol leak reveals no cap on the fuel rail pressure release valve. Took the inlet manifold off and found the two unions were in fact fairly tight already. No obvious signs of any fuel esacpe otherwise, so I have to assume something was pressing down on the fuel valve. Simple solution, put a new cap on.
HBV looks fine and no sign of leakage. No visible signs of oil leaks at the back either. Cleaned the breathers which had NOT been done properly at all. And did the throttle boddies which were manky! Not been cleaned and thus were still blocked which is why the rockers were still leaking. Also replaced the servo pipe which was broken. Put that all back together after cleaning the plenum black box and replacing the two missing seals for that box.
Put new radiator in after observing a lot of green dye from the middle of the condensor, which would explain why the air-con is not working.
Radiator went in beautifully and I connected everything back up. Put the bagpies etc back in and filled it with a can of Jizer first then the rest was water. Started it up and ran up to temp, then switched off. Scalded my hand when the radiator drain was turned 1/4 turn. I don't kniow why, I had already loosened it off when it was off the car, all I did was turn it a bit. That hurts still.
Anyway, drained off then refilled with clean water anbd ran it up to temp again. Holding level, so pressurised system with the cap and then left running upto full temp. 98 and the fan cut in. Perfect. Down came the temp to 95.
Drained all off again and this time fileld with 50/50 antifreeze mix. Ran up to full temp again before road testing. Road test proved not great news. Car runs at about 98 most the time, but goes upto 100 everytime you stop.
I will flush it all thorugh a few more times I think, but I am steering towards this condesor now. If it is blocked badly it will restrict some air flow.
Anyway, enough for today. Drives nice although I am pinching the real plug leads off the 2000 reg one. These ones are proper numpty ones.
Oh, almost forgot. Someone had stripped the front right plenum bolt at some time. It had been helicoiled, so I will be changing the inlet manifold when  do the leads. I don't like stripped threads at all. Easy enough job. Don't people use torque wrenches anymore??? Well i know me and Mark do, but what about you 'orrible lot? Come on, own up????
So. Thats the Elite for today anyway.
Jobs still to do:
Cambelt, water pump, oil, filters etc. Also plug leads and DIS pack swap. Climate bulb lights, Condensor change and aircon regas. Job finished. The car might be too nice to sell. I cannot really justify keeping it though, but it is ver, very nice to drive.
We'll see.
Right project 13. The W-reg
Stripped down to cambelt removed from scratch in 8 minutes flat. My record by a long way - and that did include fitting the locking kit!. Couldn't do a lot else on this because I need a T55 bit and haven't got one in my vast collection of tools. :( So, I'll poach one of teh good man Mark and hopefully do that job at the weekend now rather than tomorrow as I put my back out again thsi afternoon.
So. There you have todays updates.
« Last Edit: 12 September 2006, 16:46:33 by RonaldMcBurger »
Markie
« Reply #9 on: 12 September 2006, 16:47:04 »
Looking good Ronnie
If you want i can have a t55 posted today maybe there tomorrow - have a few (long and short) as thats what secures Rover seats in  ;D ;D
and at least i use  a torque wrench still - in fact bought a new one last week  ;)
« Last Edit: 12 September 2006, 16:47:30 by Markiec »
« Reply #10 on: 12 September 2006, 16:55:18 »
I have a spare 2.5 inlet manifold which you can have.......
nixoro
  • Hitchin, Herts
« Reply #11 on: 12 September 2006, 17:04:28 »
I take it helicoil stuff is no good only I need to do something with a couple of duff manifold stud threads and it was recommended to me.
Markie
« Reply #12 on: 12 September 2006, 17:09:18 »
not a fan of it personally.....
nixoro
  • Hitchin, Herts
« Reply #13 on: 12 September 2006, 17:11:48 »
Although If I find my car needs head work I maybe changing mine. :)
Markie
« Reply #14 on: 12 September 2006, 17:14:15 »
still need to face up to it as it will affec your resale price.......surely not though on an omega!!!
