Author Topic: Ghost in the machine!  (Read 3144 times)
jconn
  • Teeside
« on: 15 March 2007, 17:20:07 »
It appears my meega sun roof is taking on a life of its own :o. Symptoms started with an occasional whirr from the motor. Now it has taken it on itself to start tilting the roof. Only happens when driving (i.e. when ignition on) and only occasionally. Spooky! Anyone come across this and has any suggestions?
Cheers, Jeff.
ians
  • Reading
Re: Ghost in the machine!
« Reply #1 on: 15 March 2007, 18:32:04 »
Yes I've had something similar - intermittant and not for a while.
No idea really what the problem is.
philayl
  • Wirral, Merseyide
« Reply #2 on: 15 March 2007, 18:34:15 »
I had the same problem, I found that re-setting it worked for me.
ians
  • Reading
« Reply #3 on: 15 March 2007, 18:35:54 »
How do you do that?
« Reply #4 on: 15 March 2007, 19:01:39 »
How do you do that?
have a look in faq ;)
Kev
  • Glasgow
  • .:The OmegaProject:.
« Reply #5 on: 15 March 2007, 19:03:45 »
Sounds like a dodgy selector switch to me.  ::)
Resetting probably would appear to make a difference because you'd be holding the selector in to program the roof, perhaps freeing off those sticky/dirty contacts whilst doing so.
OmegaProject.co.uk .:.  Fuelled with passion...
[img name=signat_img_resize]http://i94.photobucket.com/albums/l92/xthreezero/omegaproject/oof-sig.jpg[/IMG]
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #6 on: 15 March 2007, 19:05:44 »
with the ignition on:
turn control to fully open (slide mode) and hold in until the roof retracts fully
turn control to closed position, hold in until it fully closes
turn control to fully open (tilt mode) and hold in until the roof opens fully
ians
  • Reading
« Reply #7 on: 15 March 2007, 19:06:40 »
How do you do that?
oh ok -if you insist... ;)
Cheers!
Ian
theolodian
  • I need a new avatar.
« Reply #8 on: 15 March 2007, 19:10:57 »
I just push the button in for a few seconds and it works for me.
sounds2k
« Reply #9 on: 15 March 2007, 21:40:08 »
I believe the full open & close procedure then also teaches the controller when to stop tilting or sliding as well as what the closed position is ... ??
Ghosts in my machine
  • Derby
« Reply #10 on: 16 March 2007, 11:01:43 »
It's not my fault. Honest! [smiley=evil.gif]
Dyslexic dwarves.... there not big and they're not clever!
