Author Topic: Outside Air Temp  (Read 5452 times)
Boiler Man
  • Sale, Manchester
Outside Air Temp
« on: 19 February 2007, 13:55:28 »
Hi Guy's
I'm sure this has been covered, but can anyone tell me were the Outside Air Temperature Sensor is on an 03 Facelift CDX, and how to get to it.
According to my display, it's 25 Deg C in Manchester :o.
Now I know we have global warming, but that's not possible in Feb, especially as I past a couple of brass monkeys clunching their crotches on my way home.
Cheers :y in hope.
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
nixoro
  • Hitchin, Herts
Re: Outside Air Temp
« Reply #1 on: 19 February 2007, 13:58:40 »
Try on the passenger side it maybe clipped to the bottom lip of the bumper infront of the Horn etc.
This is where the pre facelift one are so not sure if same for facelift but worth a look. :y
« Reply #2 on: 19 February 2007, 14:01:01 »
Cheers :y in hope.
It was yesterday in Bury wasn't it?  ;)
Assuming they've not moved it between pre & post face lift it's on the passenger side of the car just under the edge of the bumper.
Boiler Man
  • Sale, Manchester
« Reply #3 on: 19 February 2007, 14:09:57 »
I can't believe it ever reaches 25 C in Bury, even in Mid Summer ;D ;)
Cheers guys I'm not sure if there is a diff between Pre-Facelift and Facelift, but I'll have a look where you suggest.
Thanks :y
sophos9
  • Norfolk
« Reply #4 on: 19 February 2007, 15:31:52 »
Does your car have climate control?
« Reply #5 on: 19 February 2007, 16:02:56 »
All facelifts have climate control.....it was standard fit.
Boiler Man
  • Sale, Manchester
« Reply #6 on: 20 February 2007, 10:05:00 »
Yep, has Climate.
Had a quick look in the place suggested, but couldnt find it, I'll have a closer look later.
Is it in the same place for both Pre and Facelift?
Cheers
« Reply #7 on: 20 February 2007, 10:15:02 »
Its in the middle of the bumper on the lower edge below the washer bottle on the facelift....
The Barge Captain
« Reply #8 on: 20 February 2007, 13:52:29 »
Not expensive.  £7.65 + vat retail, £5.74 + vat TC.  Part No. 9152245
Boiler Man
  • Sale, Manchester
« Reply #9 on: 05 March 2007, 10:32:06 »
Hi Guys
Sorry if I seem a bit thick  :-[
I'm still struggling to find this outside air sensor, it's now 64 Deg C in Manchester  :o and the sensor seems to be effecting the climate when on Auto?
I've looked under the front bumper, but there is a large flat plastic plate in the way, preventing me reaching the bottom edge of the bumper.
Seems to be part of the bumper (body colour)
Do you need to take the bumper off to get to the sensor.
Hope someone can advise. :y
« Reply #10 on: 05 March 2007, 11:01:54 »
Hi Guys
Which car?
Prefacelift, on passenger side, near air injection pump.
Facelift, nearer middle I believe...
Boiler Man
  • Sale, Manchester
« Reply #11 on: 05 March 2007, 14:57:37 »
Its a Face lift model
a couple of the lads told me it's in the middle.
But I've looked under the front bumper and in the middle, there is a large flat plastic plate in the way, preventing me reaching the bottom edge of the bumper.
Do you need to take the bumper off to get to the sensor? :-/
or do you get at it from above in the engine bay?
« Last Edit: 05 March 2007, 14:59:22 by Boiler_Man »
« Reply #12 on: 05 March 2007, 15:50:19 »
Open the gap and look through the gap between the washer fluid tank and the rad fans.....its clipped into the bottom lip of the bumper with two wires to it....
Boiler Man
  • Sale, Manchester
« Reply #13 on: 15 March 2007, 23:04:04 »
Thanks for the help guys :y
I still couldnt open up a gap to see from underneath,  :-[ but I felt around from the top, from the engine bay and found it as you said below the washer bottle. right in the centre of the bumper.
Gave it a gentle squeeze, twist and pull. as I couldnt see it, and there it was.
I have now replaced the sensor, about £8 and it works fine. :)
Is it correct that it effects the climate? The faulty one was displaying 64 deg and the climate wouldnt heat set at 28. I had to set it to High to get any heat out of it. :-/
Anyway thanks again :y
« Reply #14 on: 16 March 2007, 09:40:35 »
The sensor is used by ECC to calculate how much to heat/cool incoming air...  ...so if faulty, ECC doesn't properly work
