Pages: 1 [2] 3  All   Go Down
Author Topic: Locking wheel nuts  (Read 9210 times)
Taxi_Driver
Re: Locking wheel nuts
« Reply #15 on: 16 March 2007, 04:32:14 »
I took mine off, as the Vauxhall ones are pretty naff anyway.
The later ones have spinners on to stop the socket trick, so check first...
You carnt get much later than an 03.....and mine dont have spinners on them  :'(
« Reply #16 on: 16 March 2007, 10:44:04 »
I think that should be "later lock nuts" and not later cars!  ::) I bought a set of lock nuts from Vx a couple of years back and they have a spinner on them. They are the of the 'cake cutter' design.
Ghosts in my machine
  • Derby
« Reply #17 on: 16 March 2007, 11:00:04 »
Try these Dave found at Halfords
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogI d_10151_productId_196491_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_71555_crumb_33958-31562-71551_parentcategoryrn_71555
or you could try the old socket trick
They're the ones I was on about. I tried the socket trick. Worked on one, but mine had the spinners so the stiffer ones wouldn't come loose. These gizmos dig in and crush the spinner onto the nut and allow it to turn.
Another way (if getting desperate) is to tack weld a bolt onto the wheel nut and just use a standard socket.
I'd also agree with the sentiment about not using Vx nuts to replace the removed ones. I reckon that using an air gun to put the nuts back on is probably more secure than using lockers! [smiley=smiley.gif]
Dyslexic dwarves.... there not big and they're not clever!
« Reply #18 on: 16 March 2007, 12:18:11 »
I reckon that's statement that could return to bite you on the bum on a cold wet night standing at the side of the motorway with a bent wheel brace in your hand!  ::)  ;D  ;D
  • Derby
« Reply #19 on: 16 March 2007, 15:29:33 »
You're probably right [smiley=sad.gif], but having a wheel nut key with a bent prong (thanks to a tyre fitter monkey) has the same effect.
The smart arse answer is get 'em really tight, but carry a section of scaftholding pipe to increase the force on the tyre iron. Handy also for road rage! [smiley=grin.gif]
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #20 on: 16 March 2007, 15:47:22 »
just to be sure, don't use copper grease when refitting the bolts and doing them up F.T. - leave for a couple of months and they should seize nicely!
Happened on an old company car (Golf GTI) a few years ago, I couldn't shift 'em - the AA man couldn't either, using a 1m extension on the wheel brace, kwik fit split an (undersized) socket trying, eventually it got towed to VW who removed the hub ... (!!!)
Admittedly though that was on one of the standard bolts and not the locking one which would most likely have been destroyed in the process ...
« Last Edit: 16 March 2007, 15:48:04 by sounds2k »
daveb
  • gloucester
« Reply #21 on: 16 March 2007, 17:21:48 »
Hi guys,
Spent two hours this afternoon with a bloody great hammer, some smaller sockets to bash over the locking wheel nuts and all I managed to do was remove plenty of lacquer from around the nut hole (ooer, sounds a bit rude!).
The locking nuts do have the rotating sleeve, but I managed to chisel off this ring dead easily with a screwdriver!! However, I just couldn't get any of my sockets to bash over the nut and grip on. I was worried about doing damage to the wheel, or knowing my luck, flattening my fingers I was hitting it so hard!
Looks like I will be trying the halfords option suggested by Elite Pete.
Thanks again for all the tips.
I will let you know how things go!
Cheers,
Dave.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #22 on: 16 March 2007, 17:27:09 »
Had a Mk1 Granada once, had a wheel NUT seize on the stud, stud's come through the drive shaft / hub, they are sweat fit / splined, drum on top then wheel.. (Flat Steel Wheel- fortunately)  Had to grind the nut flat to the wheel then drill the existing nut away, leaving a flush stud.  Drum off and replace 1 stud, re-sweated it in, what a sh1te of a job....  I made sure the remaining 19 studs/nuts never, ever never, never, never, ever, never would give me this problem again !!!!
What do we rekon then chaps? Do we use grease / copper slip on our studs / nuts or not...  What we say?
DC
I might just run a poll!!
« Last Edit: 16 March 2007, 17:28:01 by dave_c »
« Reply #23 on: 16 March 2007, 18:14:22 »
DC
I always use copper slip on my nuts!  ;)  ;D
« Reply #24 on: 16 March 2007, 18:21:32 »
Hi guys,
Cheers,
Dave.
You could do with one of these
I would think they'd work better with a 'windy gun'
STMO123
« Reply #25 on: 16 March 2007, 18:30:36 »
DC
 :-X
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #26 on: 16 March 2007, 19:20:06 »
I always said they were a bit strange over Bury way. ;D
TuBy's new whipping boy.
ricardo1500
  • Wolverhampton
« Reply #27 on: 16 March 2007, 20:01:06 »
Dave
If they are VX ones then the socket you need is 13/16" once you have removed the spinney thingy. Importantly you need to grind the chamfer of the end of the socket,  this means that the "teeth" that normally grip a nut will start to bite onto the locking nut as soon as it starts to hammer on.  This gave me enough of a purchase to remove one that needed a scaffold tube as an extension to my ratchet before it gave in!!!!. Dont you just love previous owners!
  Best of luck mate.
« Reply #28 on: 16 March 2007, 20:09:46 »
You'll be OK - I won't offer to grease your's!  ::)  :y
« Last Edit: 16 March 2007, 20:10:27 by Andy_B »
daveb
  • gloucester
« Reply #29 on: 16 March 2007, 21:09:31 »
Dave
  Best of luck mate.
Hi Ricardo,
Yes thery are VX ones. and as many others have already said. I will not be replacing them with VX ones. I have got some from a motor factor for £20. I will be getting one of the locking nut removal sockets with a reverse thread from Halfords when they get some more into stock on Tuesday - then I'll have another go. What a sod!
Dave.
Pages: 1 [2] 3  All   Go Up
