Pages: 1 [2] 3  All   Go Down
Author Topic: HELP. 2.5 running rough  (Read 7765 times)
irratic
  • STOKE-ON-TRENT
Re: HELP. 2.5 running rough
« Reply #15 on: 14 March 2007, 22:05:49 »
just rechecked and neither multiram is working.. but have vacuum up to the solenoids... it runs flat alright , don't suppose an ecu off a 3litre will fit just to try it?????? just so happens ive got one lying around..
Unlikely to be ECU.  Won't work anyway unless you have matching immobiliser (or a tech2)
so if i could get hold of another 2.5 ecu to try it, it wouldn't work????
STMO123
« Reply #16 on: 14 March 2007, 22:07:15 »
Does the EML light up ok when you switch on? ie bulb hasn't gone?
Bo Bo
  • Coventry
« Reply #17 on: 14 March 2007, 22:09:32 »
perhaps its not quite a missfire in the term... while driving it seems to miss, yes .. but perhaps more like the old carb cars used to if they were fuel starving when you were accelerating... i really just put it down to a missfire... non of the vaccum pipes have been touched since the car was running fine...
Sounds just like mine except my multirams are working.....
« Reply #18 on: 14 March 2007, 22:13:23 »
No, it wouldn't. You need ECU to be coded to immobiliser, and the key transponders to be programmed to immobiliser. If you can get ecu, immobiliser, and transponders from same car, that would be OK.
Though its extremely unlikely you have a ecu issue, that would be rare (unless you take it to a dealer, and thats because they are too stupid to use the diagnostic equipment)
irratic
  • STOKE-ON-TRENT
« Reply #19 on: 14 March 2007, 22:13:43 »
EML lights up and goes off as normal when you first start .... me thinks over insure and burn it....its driving me mad...as the EML hasn't come on (during running) i'm assuming it wont have stored any codes??
« Reply #20 on: 14 March 2007, 22:17:45 »
Non working multirams are noticable, but shouldn't make it seem really bad, or significantly 'holding back', esp at high revs.
irratic
  • STOKE-ON-TRENT
« Reply #21 on: 14 March 2007, 22:19:14 »
if its unlikely to be ecu .. ... and i have vaccum to both solenoides , which are controlled by ecu. but no vaccum after them either both solenoids are buggered or i have an electrical issue going to both of them.. are there any fuses to them?? i accept the fact that the multirams not working may not be the problem i'm having , but never the less its the only thing ive found wrong ..LOL.. i think i need alcohol....lots of it..
« Reply #22 on: 15 March 2007, 08:00:47 »
Think we are all diving off down dark alleys here.....forget the ECU....the engines running isn't it....that should give a clue as to the condition of the ECU...remember, its only a small computer...
Multirams....are the vac lines connected to the correct bits on the solenoids.....is the vac feed to the nose of the solenoid and the output on the side.....if not, you get a vac leak and no multiram operation as when the valve is shut, the output is vented to atmosphere.....
This would also cause a vac leak and hesitation....plus a possible miss fire .
Its cases like this where I use two of the simplest and most effective diag tools you can get.....a vac gauge and a length of tube....
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #23 on: 15 March 2007, 08:10:47 »
... have you tried the paperclip test, in case there are any stored fault codes that may help?
irratic
  • STOKE-ON-TRENT
« Reply #24 on: 15 March 2007, 18:24:51 »
ive checked positioning of the vac lines.. they are all ok and the vacuum is strong.. i do have a spare solenoid from behind the front multiram so i'll change that later see if it makes any difference.. perhaps both solenoids have gone down
irratic
  • STOKE-ON-TRENT
« Reply #25 on: 15 March 2007, 18:25:50 »
not done the paper clip test as the EML hasn't been on so didnt think it would of stored any codes
irratic
  • STOKE-ON-TRENT
« Reply #26 on: 16 March 2007, 18:21:13 »
DONE IT (I THINK) right lads.. cured the multiram prob.. powered up the solenoids and blew them threw .. must of had bits of dust in them... now the multirams work... it didn't cure the missfire... but now ive cured that for future reference.. when checking the leads it was cold and damp last night so didnt notice much. i.e no oil around the plugs.... been out today and did a reinspect... water in the rear n/s plug.. the worst one to get at and the one you cant look down.. sucked it out dried it with hair dryer and hey presto SORTED...i assume the engine ran fine untill the water turned into steam then caused a bad connection. as the plug lead is relatively sealed the steam could't go anywhere so condensed . so at cold it was fine.... the water runs around the plastic catch plate where the wipers are then soakes the soundproofing underneath which is right above that plug lead.....thanks for all your help
STMO123
« Reply #27 on: 16 March 2007, 18:33:04 »
Well done. Really glad you sorted it  :y
irratic
  • STOKE-ON-TRENT
« Reply #28 on: 16 March 2007, 20:30:54 »
spoke to soon AAAAAHHHHHHHHHHHHHH. just done a load of miles up the motorway and this is the problem....it misses when you slightly accelerate... boot it with kickdown 6000 revs no problem , pulls your arms out. hold it at a steady 30,50,70 no problem.touch the accelerator slightly and hold it there it misses until its climbed speed wise to a coasting speed then misfire goes. stop at a juntion and pull off it missfires again untill you reach the speed where its not trying to accelerate. if while its missing you floor it. it'll drop down a gear and pull away no problem.... an ideas lads ????? anything..
« Reply #29 on: 16 March 2007, 21:24:00 »
Sorry, no real ideas. No more water has got in has it?
I've always had a feeling this is HT related, and said so earlier in post. I still think the same. Though usually shows up under heavy acceleration as well.
Are the plugs good? What about leads and DIS? Has water been dripping on DIS?
Pages: 1 [2] 3  All   Go Up
