Author Topic: Central Locking 02 Omega  (Read 1436 times)
omegadan2.2i
  • Worksop, Notts
« on: 18 March 2007, 21:44:59 »
Hi all
Just recently bought a 2002 2.2i CD Saloon and the central locking on the passenger front door was 'lazy' (i.e. would not fully raise or lower the button when locking/unlocking), however now it does NOT work at ALL!!! >:( >:(
I want to know if this is a common fault and is it an easy fix (i.e a few squirts of WD) or whether I need a new solenoid?
Obviously I will need to remove the door panel - what is the best way to remove it without causing much cursing and swearing!! (and possible damage!!)
Cheers :)
Dan
Re: Central Locking 02 Omega
« Reply #1 on: 18 March 2007, 21:46:27 »
Fairly common....
You're going to need replacement CDL motor.  There is a guide in Maintenence Guides section about removing facelift doorcard.
omegadan2.2i
  • Worksop, Notts
« Reply #2 on: 18 March 2007, 22:02:21 »
Cheers  ;)
How much are these from VX?  Do you know the part no.?
Dan
« Reply #3 on: 18 March 2007, 22:04:48 »
Cheers  ;)
Dan
No idea, but I imagine not cheap.
The passenger side is normally fine, so see if anyone here has a spare going cheap...
