Author Topic: Power Steering Mod  (Read 2141 times)
omegalyn
Power Steering Mod
« on: 14 March 2007, 13:14:05 »
Hi there,
Can anyone tel me if it posible to make the power steering lighter. I have got a paralyzed right arm and finding my Omega 2.0 16v a bit heavy to drive with my left.  Has the V6 got a more powerful pump that can be put on? but I am sure it won't be that easy! . I find it very camber sensative have changed the wishbones and idle control arm which has made it not pull to the left as much, check tyre pressure every week as this can make a difference, but I find it heavy to steer at low revs, e.g. parking.
Any advice.
Thank you
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
Re: Power Steering Mod
« Reply #1 on: 14 March 2007, 14:40:27 »
I know it's no help for your Omega, but I used to have a Ford Scorpio. It had the lightest steering of any car that I have ever driven.
Growing old disgracefully...
« Reply #2 on: 14 March 2007, 14:46:30 »
The V6 servotronic setup can be adjusted via Tech2 to adjust the assist level....but not the 2.0....not sure if it can be altered though.....
« Reply #3 on: 14 March 2007, 19:53:31 »
Hi there,
Any advice.
Thank you
If its just heavy at lows revs, it may just be a tired pump?
omegalyn
« Reply #4 on: 14 March 2007, 23:42:51 »
Thank All,
The servotronic setup sounds a good idea, I wonder how light it can go?. Might be a good excuse to upgrade to a V6,  ;).  Yes it could be the pump, how can I test it, Sound expensive to replace.  What dos a Tech2 look like, is it what the Vx garage plugs into the dash and can I buy one off the shelf .
Thanks again
Omegalyn.
« Last Edit: 14 March 2007, 23:49:20 by omegalyn »
Admin
« Reply #5 on: 15 March 2007, 12:24:27 »
Go for V6... great upgrade! ;)
Servotronic has 3 settings (adjustable on TechII) as I recall.
Not sure on replacing the pump on the 2.0, but it is easy on the V6.
Tech II is indeed the piece of kit the Vx garage plugs into your wallet!
You can buy one.... but be warned it is VERY (ie thousands of pounds!) expensive.  :o
The Administrator.
« Reply #6 on: 15 March 2007, 18:52:43 »
Does the steering lighten up again if you blip the throttle? If so, pump sounds tired...
omegalyn
« Reply #7 on: 19 March 2007, 08:53:05 »
No the power steering stays the same no matter what revs, I have noticed that the front of the car moves from side to side when going from lock to lock, is this normal or have I not put somthing back on the right way like the steering idler?
Thanks
Omegalyn
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #8 on: 19 March 2007, 10:42:01 »
Thanks
Omegalyn
Thats the tires forcing the whole car to move at standstill - don't think its very good for it mind..
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
