Author Topic: Central Door locking motor  (Read 2598 times)
« on: 19 March 2007, 10:12:32 »
My dads 2001 facelift has developed the "lazy" door locking problem on the drivers side.
No doubt its probably the motor that's gone, but I have 2 questions:
1. Are central door locking motors the same between facelift / pre-facelift?
2. I am very nervous about the air-tight inner film on the door, as this is used as a sensor for the side air bags. Should i disconnect the battery before doing this job? Also whats the best stuff to use to seal it all up again?
Cheers
Re: Central Door locking motor
« Reply #1 on: 19 March 2007, 10:36:22 »
Cheers
The weather shield bit is not 'airtight', but is used as part of side airbag system. It needs to be 'airtight enough' so the pressure sensor in the door can detect pressure increase when the door is hit by and object.
So, don't tear it, instead peel it off (only enough to get to what you need). Restick with any glue if it is not sticky enough
« Reply #2 on: 19 March 2007, 10:39:55 »
Cheers, just scared of buggering it up so that come a crash the side air bags won't go off..
Hoping the CDL motors are the same, cause got a feeling James might have one spare!
« Reply #3 on: 19 March 2007, 10:41:22 »
Apart from I have already bagsie'd it.... ;)
« Reply #4 on: 19 March 2007, 11:03:07 »
« Reply #5 on: 19 March 2007, 12:10:26 »
They did change connector type around 97/98ish, so you both might be buggered..!
« Reply #6 on: 19 March 2007, 12:39:49 »
Is the connector on a bit of loom from motor (rather not modify car loom)?
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #7 on: 19 March 2007, 16:11:46 »
Better cancel my bid on that pre 98 one I had my eye on also  >:(
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
« Reply #8 on: 19 March 2007, 16:41:04 »
I seem to remember they are about 30ish new....so bare this in mind if buying second hand......
« Reply #9 on: 19 March 2007, 16:51:45 »
30 quid is that all? - I'll get one brand new then, sod second hand!
Cheers Mark  :y
