Author Topic: Front wishbones and links.  (Read 3010 times)
rob.b.666
  • Blackpool
« on: 18 March 2007, 21:48:45 »
Quick question again. Are these replacable by the 'average joe' - i.e. me, with a good general knowledge and experience of vehicle maintenance ?
I'm not looking at trying to replace the bushes, as I know this needs special tools and I know the front will need re-aligning, once done.
Any advice (a 'how to' would be good!) welcomed.
Cheers.
Rob
(P.S - ditto crank sensor !)
My most hated six words...... 'It's a common problem on Vauxhalls' ...........arrrggghh !!!!
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Front wishbones and links.
« Reply #1 on: 18 March 2007, 21:50:42 »
Yes, apparantly easy done.  Matchless, JasonH and others have done it recently.
Hang on and I'll find the link :y
« Last Edit: 18 March 2007, 21:54:18 by Chopsdad »
« Reply #2 on: 18 March 2007, 21:53:02 »
Yes. Even I have done it, so can't be too hard ;)
Chopsdad
  • Keep it clean!
theolodian
  • I need a new avatar.
« Reply #4 on: 18 March 2007, 22:47:38 »
We'll see if I agree next weekend after I do mine.  I may have some choice words about the matter.   :P
It took me a lot longer to do the cambelt and cam cover gaskets than people said . . .  ::)
 :D
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #5 on: 18 March 2007, 23:31:31 »
I found removing the track rod end helped as it allows the strut to move a bit more. Also try and clean the crud off the thread of the drop link, it will make undoing the nut much easier if it doesn't have to cut through that on its' way out ... but I managed to do boith side of mine (eventually) and I'd never attempted it on any car before ... it's doing the nuts up afterwards that's difficult though, especially the vertical one - really you need ramps or a pit ...
rob.b.666
  • Blackpool
« Reply #6 on: 18 March 2007, 23:38:59 »
Is it worth buying a crank sensor off e-bay, or can we get trade club discount, via this forum ?
JasonH
« Reply #7 on: 19 March 2007, 07:52:46 »
The main challenge with wishbones is getting the bolts undone (you'll need an 18mm socket too).
theolodian
« Reply #8 on: 19 March 2007, 08:22:24 »
My struts will be out completely, not changing the droplinks though.  Why do up the vertical bolt on the ground?  It shouldn't move.
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #9 on: 19 March 2007, 18:51:36 »
Her I go again, Did mine last week, parts from VSC on e-bay, £55 for both wishys delivered to my door, excellent quality too...  The job:  Mmmmmmmmmmmmh :-/, tough stiff nuts!  Not me, the Omega ;D ;D, But YES, easy job...
DC
GO FOR IT
sounds2k
« Reply #10 on: 19 March 2007, 19:04:23 »
from what I remember hearing, it's to do with the twisting of the rubber bush that occurs if you do the nut up tight with the car in the air & then lower it to the ground, this means it will then be under tension all the time and makes it wear faster ... apparently ... also, you're supposed to have 2 x 75Kg weights in the front of the car when doing the bolts up as well ...
theolodian
« Reply #11 on: 19 March 2007, 19:39:03 »
That makes sense for the horizontal bolt, but doing the vertical bolt on the ground seems like overkill.
rob.b.666
  • Blackpool
« Reply #12 on: 19 March 2007, 23:37:38 »
Could just ask two mates to sit in the car, while you nip them up (bolts, that is)!
