Pages: 1 [2] 3  All   Go Down
Author Topic: Elite top end rebuild  (Read 7278 times)
Re: Elite top end rebuild
« Reply #15 on: 20 March 2007, 17:56:38 »
Heres my theory
Cr=((Pi/4)xb2xs+Vc)/Vc
A bit of simple alegbra gives:
Vc=((Pi/4)xb2xs)/(Cr-1)
Which using b=8.16cm and s=7.96cm (I use cm which goes against the grain a bit because I want Vc in cc's)
gives Vc = 42cc
Plug this value back into the original equation using the 3.0 bore and stroke and you get the Cr....
« Last Edit: 20 March 2007, 17:57:26 by Mark »
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #16 on: 20 March 2007, 19:33:02 »
Oh i get it now, i think :-/ :-/ :-/ :-/ :-/
« Reply #17 on: 20 March 2007, 22:11:42 »
Heres my theory
gives Vc = 42cc
riiiiiiiiiight then.  :-/
I am sticking to computers!  ;D
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #18 on: 20 March 2007, 22:20:07 »
Heres my theory
gives Vc = 42cc
OK ... so s=stroke (79.6mm) and b=bore dia. (81.6mm) ... what's x???  :-/
seeing that brings back memories ... of headaches!!!  :D
theolodian
  • I need a new avatar.
« Reply #19 on: 20 March 2007, 22:21:26 »
Heres my theory
gives Vc = 42cc
multiply  ::) ;D
« Reply #20 on: 21 March 2007, 14:02:05 »
Mark, in your wisdom, am I going to have any big problems putting the 2.5 heads on??
« Reply #21 on: 21 March 2007, 15:18:55 »
It will give you 'head' aches.....unless you want to build a race engine!
Plus you would want to use the 3.0 sodium filled exhaust valves any way.....
« Reply #22 on: 21 March 2007, 15:19:46 »
Heres my theory
gives Vc = 42cc
Tunnie, the ONLY thing a computer can realy do is computations......yes lots of them.....but its still maths!
« Reply #23 on: 21 March 2007, 15:36:34 »
What sort of headaches mark, serious ones, or niggles?
Happy to keep the car on 99RON....
« Reply #24 on: 21 March 2007, 15:37:12 »
also, what would it do to emissions....
« Reply #25 on: 21 March 2007, 15:41:29 »
In theory, the engine would require a higher octane fuel plus, the knock sensor is likely to retard the timing further....all to prevent pre-ignition.
More NOx would be created as a result of the higher compression but, in theory you should get better efficiency (you might struggle to actualy achieve this!)
The V6 (2.5 and 3.0) have a pretty high compression ratio already......
« Reply #26 on: 21 March 2007, 15:43:35 »
NOx isn't measured on MOT is it?
« Reply #27 on: 21 March 2007, 16:38:11 »
No, but your biggest problem will be knock. Yes, the engine has knock sensors so it can theoretically cope but who knows how much timing adjustment the ECU will allow before it throws in the towel and goes into limp-home? Or maybe it will just lob in as much correction as it allows and yet still hole a piston?
Compression ratios this high are extreme even in tuned engines, and those generally have more aggressive cams which result in less VE in the medium rev range where knock can be a killer - meaning that the effective CR is lower until they hit high revs. They also generally have forged pistons at this level so are much stronger and able to cope with a little knock.
I think trying this with an otherwise stock setup where you can't adjust fuel and spark is asking for trouble - unless it has been tried before with success. It's an easy upgrade (just like 3.0 cams in a 2.5) so if it worked, people would be admitting to have tried it  ;)
(just like they do with 3.0 cams in a 2.5). The silence speaks volumes, IMO!
It would be a real shame to go to all the trouble and expense of a top end rebuild only to find out you've got an engine that doesn't run.
« Reply #28 on: 21 March 2007, 16:56:29 »
I agree with all of this logic... but... it's Sooooooo tempting to try it ;D
theolodian
« Reply #29 on: 21 March 2007, 17:03:15 »
If you're sure that you will be running LPG most of the time then the arguement changes.
Pages: 1 [2] 3  All   Go Up
