Speedo/ABS/TC strangeness
Started by Paulus, 27 February 2007, 15:46:13
Paulus
The number begins with a W...is that significant? Is there a specific ABS module that I need to get? :-?
Growing old disgracefully...
QuoteThe number begins with a W...is that significant? Is there a specific ABS module that I need to get? :-?
They all start W0L - its the end bit thats important...
Paulus
Errrrrr...yeah....I knew that. I wat just testing.  ::)
Anyway, it looks like the end bit starts with an X.
What now?
99 model then.  Still has the less reliable ABS ECU though - 98 onwards suffer.
May be worth getting ABS fault codes read if you can cheaply, and also clean and regap ABS sensors.
Paulus
QuoteBTT
BTT???????? Eh? What's that mean?
QuoteBTT
BTT or BTTT means Back To Top or Back To The Top, and is a way of bumping an older thread back to top of list.
Personally, I'm not a fan, as it can give the impression you are unhappy with the responses, so some may consider it 'rude', as with any written conversation, it can be taken in a manner different to what was intended...
