Author Topic: Red hot battery terminals  (Read 4769 times)
« on: 25 March 2007, 13:39:24 »
Driving home with project Elite, I stopped in the services, checked under the bonnet. Noticed that the neg terminal was too hot to touch, scalding hot.
Later on, noticed that the positive one was red hot, but negative one was cold.
Obviously an electrical fault.
The smaller engine management wires do not get hot, it's just the thick ones going from battery to starter via alternator. And I guess I'm right in thinking, that this is the only circuit in the car not fused?
With the ignition on, but no engine running, the lead doesn't even get warm.
But as soon as the engine's run for a couple of mins, it gets red hot, at the terminal end.
Ideas? I was thinking Alternator, based on the above......
Re: Red hot battery terminals
« Reply #1 on: 25 March 2007, 14:04:25 »
Try measuring the voltage across the battery when it's running. Could be regulator failure in the alternator overcharging the battery.
Also, make sure the connections at the battery are in good condition, especially where the charging lead from the alternator meets the battery clamp.
« Reply #2 on: 25 March 2007, 14:06:13 »
I was just thinking of putting my known good alternator on there, during the rebuild :)
Could there be anything else causing it, but alternator?
« Reply #3 on: 25 March 2007, 14:14:28 »
Or the starter is not disengaging.....is the starter feed from the ignition switch turning off....
« Reply #4 on: 25 March 2007, 14:16:56 »
If it only happens when it's running I'd say it's either the alternator or the quality of the wire / connections at the battery terminals. If there is a little resistance here it will get hot when it's passing the output of the alternator. Probably more likely to be the latter TBH but I guess if you've got a known good alternator it's going to be much easier to change it with the heads off.
« Reply #5 on: 25 March 2007, 15:23:33 »
Could feasibly be a fault with the battery...
« Reply #6 on: 25 March 2007, 15:27:03 »
Ok, so far, replace battery (got known good one) and replace alternator!
spiridusul_rau
  • Romania
« Reply #7 on: 25 March 2007, 15:34:49 »
Hi,
first you must measure the voltage of the battery with engine off. Then start the engine and measure again the voltage.
« Reply #8 on: 25 March 2007, 15:36:02 »
If Alternator shot, I would expect batter voltage to be above 15v at 3000 rpm...
« Reply #9 on: 25 March 2007, 15:36:58 »
Hi,
That will be a bit tricky with the cylinder heads off it ;)
I will replace all the likely culprits whilst apart, and take it from there.....
« Reply #10 on: 25 March 2007, 17:40:08 »
Hi,
Errr, do it before taking heads off!
« Reply #11 on: 25 March 2007, 17:41:46 »
Hi,
That would mean fitting inlet manifold, inlet bridge, coolant bridge, plenum, bagpipes.... remember I've already started stripping the other day ;)
« Reply #12 on: 25 March 2007, 17:47:03 »
Hi,
I would have checked before I started stripping....
spiridusul_rau
  • Romania
« Reply #13 on: 25 March 2007, 17:48:49 »
« Reply #14 on: 25 March 2007, 17:50:43 »
Hi,
I'll renew the alternator, starter, battery anyway with bits off the other car, and cabling.. there is not much else it can be.....
