Author Topic: Oil cooler change....Part Numbers....  (Read 2164 times)
stevebubs
  • Reading
« on: 25 March 2007, 20:57:29 »
Looks like I may need to do an oil cooler change in the near future - coolant level is dropping from max-min over a period of about 3 months and has a mayo like film on top.
Anyone got a list of part numbers, and approximate costs (TC / non-TC) so I can start figuring  out how much I'm gonna have to pay to get the bits?
Ta
Stephen
Markjay
  • London
Re: Oil cooler change....Part Numbers....
« Reply #1 on: 25 March 2007, 22:18:31 »
Apparently you will need for the job:
Note:     Use new banjo bolt.
Parts:                                Part-No.:        Catalog-No.:
1 Heat Exchanger (Stainless Steel)    13 101 668       90 06 313
2 Banjo bolt                          90 424 578       13 36 977
1 Sealing                             09 163 307       15 03 301
4 Seal ring                           11 076 852       20 91 055
2 Seal ring                           90 409 175       06 50 760
Alas, no more Omegas....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 25 March 2007, 22:33:15 »
not on tc but i got my cooler and plate here
http://cgi.ebay.co.uk/Vauxhall-Oil-Cooler-Cavalier-Vectra-Omega-Sintra-Signum_W0QQitemZ200074437272QQcategoryZ10404QQrdZ1QQssPageNameZWD1VQQcmdZViewItem#ebayphotohosting
This is where i bought mine from and as cheap as you will get it......
Also need the parts listed above by markjay which will add another £20.
Finally oil filter and oil for oil change and loads of coolant to change / flush it ( that is on tc)
Hope this helps  :y
oh and do it the mark dtm way ------dont bend the oil cooler pipes - remove them at filter  ;)
« Last Edit: 25 March 2007, 22:35:51 by Markiec »
Markjay
  • London
« Reply #3 on: 25 March 2007, 23:05:37 »
Markie
« Reply #4 on: 25 March 2007, 23:16:36 »
markjay strikes again with his invaluable picture / diagrams  :y :)
Markjay
  • London
« Reply #5 on: 25 March 2007, 23:22:45 »
Thank you Markie....  :-[ :)
« Last Edit: 25 March 2007, 23:23:17 by markjay »
stevebubs
  • Reading
« Reply #6 on: 26 March 2007, 00:02:18 »
Thanks for the quick replies folks.
Guess while I've got the system drained I could also replace the Heater Bypass Valve at the back of the bay - gonna have the car a while and it's rolled over the 100k miles so it's just gonna be a matter of time I guess.
Any part numbers for this around?
Chrs
Stephen
Markjay
  • London
« Last Edit: 26 March 2007, 00:45:56 by markjay »
stevebubs
  • Reading
« Reply #8 on: 26 March 2007, 01:19:59 »
Ta!!!
