Author Topic: MV6 won't start without throttle  (Read 1942 times)
« on: 26 March 2007, 21:48:09 »
Once started, idles fine.
Did have EML on earlier, haven't read codes, not sure it would be related anyway...
Taxi_Driver
Re: MV6 won't start without throttle
« Reply #1 on: 26 March 2007, 21:58:09 »
Is this hot or cold or both?
Does it stink of petrol, when cranking?.....just wondering if it was flooding and knowing you when you say without throttle, that probably means you've got year foot on floor.....which i think shuts the injectors off.....so you'll be getting more air in...and it starting  :-/
« Reply #2 on: 26 March 2007, 21:59:34 »
Its as if the ICV is shot (I did clean yesterday), but it idles fine once started....?
theolodian
  • I need a new avatar.
« Reply #3 on: 26 March 2007, 22:03:08 »
My immediate thought is plenum leak.  Then I remembered that you just had it off . . .
« Reply #4 on: 26 March 2007, 22:07:37 »
As JamesV6CDX will confirm, I suspected an air leak....
theolodian
« Reply #5 on: 26 March 2007, 22:15:25 »
The important distinction is that it is probably behind the throttle body if opening the throttle helps.
« Last Edit: 26 March 2007, 22:16:11 by theolodian »
« Reply #6 on: 26 March 2007, 23:49:06 »
Yup, heard it running last night, definately a slight leak, but I'll be buggered if I could confirm where. Sounded towards passenger side... that suspect ICV pipe might have something to do with it?
« Reply #7 on: 27 March 2007, 08:41:45 »
Possibly, but that pipe, although needs replacing when I can source a good one, is still reasonable airtight I reckon....
« Reply #8 on: 27 March 2007, 19:06:14 »
I see what my services are required for now  ::)
As PM, Sunday should be good for me  :y
Page created in 0.022 seconds with 20 queries.
