Author Topic: Gear box oil off Opie oils  (Read 3692 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 25 March 2007, 14:55:45 »
Hi there,
I am looking at renewing my gearbox oil but I cannot fathom which one I need off the Opie website.
I have a 2.5 petrol auto
VMT
Gaffers
Re: Gear box oil off Opie oils
« Reply #1 on: 25 March 2007, 15:24:09 »
Hi there,
VMT
Gaffers
Must be Dexron III
Gaffers
« Reply #2 on: 25 March 2007, 16:45:22 »
Sure, but I heard that Opie did 5L for #25 ish quid yet I cannot for the life of me find it, just the 1L for 7.99...... yurk!!
« Reply #3 on: 25 March 2007, 17:45:11 »
Most places do.  My local factors near work do Coma 5l Dexron III for £22 retail (and they give trade if you show TC card ;))
Markjay
  • London
« Reply #4 on: 25 March 2007, 18:12:55 »
The ATF recommended by Mark DTM iirc:
http://www.opieoils.co.uk/performance_lubricants/fuchs.aspx
Fuchs Titan ATF 4000 (Dexron III) 5L £29.99
Fuchs is top-notch German brand used as OE by German car manufacturers.
Alas, no more Omegas....
Martin_1962
« Reply #5 on: 25 March 2007, 20:49:56 »
Better explained on one word - used to use it in bikes
Silkolene.
Now why call your self Fuchs when Silkoline was such a strong brand
Essex_Andy
  • Have a guess?
« Reply #6 on: 28 March 2007, 00:20:57 »
Having had an engine on my motorbike rebuilt my Mistral Engineering (a proven engine builders) they advised me to stay well clear of Silkolene....they said if foams too much.
l was told kendall Oil is the best you can get but hard to find in the UK
Castrol gets my money 99% of the time
If an artic overtakes you, you're driving too slow!!!!!!!!!!!
Markjay
  • London
« Reply #7 on: 28 March 2007, 12:53:11 »
Oil thread.... I'm going to just sit back and enjoy this one...  8-) keep them coming!  ;D
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #8 on: 28 March 2007, 20:27:05 »
I just bought a 5 litre container of this stuff:
- £15.99 inc. VAT from Halfrauds with trade card  :)
soooooooo ... what else do I need to buy, I'll be sourcing the parts and getting a local garage to fit it as I don't have a suitable lift or ramps ...
I'm thinking along the lines of:
P/N 96014235 - large sump gasket
P/N 96014234 - small sump gasket
P/N 96015432 - filter assembly
... is there anything else needed? ta  :y
Gaffers
« Reply #9 on: 29 March 2007, 13:57:34 »
How much was the dextron III without the TC?
I've heard that when replacing the gearbox sump you just need some gasket maker compound which works better than a new gasket, but I cant remember which one...
sounds2k
« Reply #10 on: 29 March 2007, 18:10:59 »
retail price is £20.99 (from Halfrauds) ... not sure about the gasket maker, I've heard of it being used on the engine sump but not the gearbox ones ...
Markjay
  • London
« Reply #11 on: 29 March 2007, 19:27:04 »
The Vx gasket set is only around £13 Trade, but Marks DTM says that the gaskets are no good, better to use Loctite liquid gasket instead.
The filter is quite expensive - circa £60 - and if it is not broken then it can be cleaned.
You will also need the drain plug washer - p/n 11023582 (13 Pence...)
sounds2k
« Reply #12 on: 29 March 2007, 19:48:14 »
OK, thanks for that - is there a Vx P/N for the loctite instant gasket or will the garage need to source it? ta  :y
