Author Topic: What are those cogs on the rear diff for?  (Read 2023 times)
Taxi_Driver
« on: 28 March 2007, 21:04:11 »
Noticed today.....when my omega was up in the air....a cog type wheel on either side of the rear diff.
I discovered a sensor on each one.....i asked one of the guys in the garage (The Boss is away)....his answer was ummmmm....abs sensor.....was he right??
Also why is one of them nicely rusty on the sensor edge and the other is nicely shiney?
I guess the sensor is rubbing on the wheel? should it be? Dunno  :-/
The side thats shiney has got an oil weep.....so apart from the edge thats shiney the rest of the cog is a bit 'damp' with oil.
Any ideas/help appreciated  :y
hotel21
  • The Kingdom of Fife
Re: What are those cogs on the rear diff for?
« Reply #1 on: 28 March 2007, 21:06:57 »
Its the ABS gubbins, TD.  Sensor picks up when one shaft stops rotating against the other and applies/reduces brakes accordingly.  Believe its also used by the traction control, but sit to be corrected...   ;D
Same thing also on front wheel bearing housing with sensor on the carrier to sense when wheel stops rotating.  Check the image on  this item to see what I mean.
HtH
B
« Last Edit: 28 March 2007, 21:11:13 by hotel21 »
Taxi_Driver
« Reply #2 on: 28 March 2007, 21:11:50 »
Its the ABS gubbins, TD.  Sensor picks up when one shaft stops rotating against the other and applies/reduces brakes accordingly.  Beleive its also used by the traction control, but sit to be corrected...   ;D
HtH
B
Cheers Broocie,  :y
20yo mechanic type blokey was right then......i thought he was just guessing  ;D
I havent got TC.....so not that on mine  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #3 on: 29 March 2007, 06:38:48 »
The cogs are there so your expert mechanic can get a cold chisel and a lump hammer, to check that the diff spins easily.....
I like red cars
DaveL
  • Nr. Cupar, Kingdom of Fife
« Reply #4 on: 29 March 2007, 20:36:14 »
There should be an air gap between the sensor and the toothed ring. If one of the sensors has been catching on the toothed ring then it could well be cream crackered. You may get an ABS fault light come up if this is so. :)
 8-)
DaveL
Taxi_Driver
« Reply #5 on: 29 March 2007, 21:44:36 »
 8-)
DaveL
Cheers......The ABS light isnt on at the moment, but i will know where to look if it does come on  :y
