Author Topic: Cool running  (Read 4361 times)
Martin_1962
Cool running
« on: 30 March 2007, 19:08:45 »
Struggled to get over 80degrees, turned on ECO (turned off compressor), temperature got up to 90deg or so.
Where do I look then!
Re: Cool running
« Reply #1 on: 30 March 2007, 19:16:48 »
My guess would be a thermostat that's not closing fully. Switching the air on on will start up the auxiliary cooling fans resulting in more airflow through the radiator and a cooler engine, if the engine temperature is not being controlled properly by the thermostat.
Try starting the engine from cold and feeling the temperature of the top radiator hose, and also the engine temperature at the heater hoses (with heater on). The heater hoses should warm up gradually, and start getting warm pretty much as soon as the engine starts.
The top radiator hose shoiuld remain cool (it may warm up a little) until the engine has reached normal operating temperature and suddenly get very hot when the thermostat opens. If it warms up with the heater hoses I would suspect a dodgy thermostat.
If the air con affects the temperature gauge immediately rather than after a few minutes running it could be a bad earth to the engine block, with the extra load from the fans affecting the reading from the temperature sensor in the coolant bridge.
Taxi_Driver
Re: Cool running
« Reply #2 on: 30 March 2007, 20:15:11 »
If you let it warm up to 90ish then take it for a blast.....if the them temp drops down to 80 or below....then as Kevin says sounds like thermostat knacked.
Tho i do like his method to mine  ;)
Re: Cool running
« Reply #3 on: 30 March 2007, 20:21:19 »
Tho i do like his method to mine  Wink
On the contrary. Any excuse for a blast! [smiley=evil.gif]
Re: Cool running
« Reply #4 on: 30 March 2007, 21:35:14 »
Sounds like stat. Reason A/C cools it down more is because when a/c on, so is one of the rad fans...
Martin_1962
Re: Cool running
« Reply #5 on: 30 March 2007, 21:36:16 »
Thrashed the nuts off it air con off gets to 90 then cools down to 80 with aircon back on.
Last summer was in 90s most of the time solo or towing gas or petrol
Martin_1962
Re: Cool running
« Reply #6 on: 30 March 2007, 21:38:01 »
 I reckon it explains the poor consumption as well
Re: Cool running
« Reply #7 on: 30 March 2007, 21:40:58 »
It certainly won't help mpg...
Re: Cool running
« Reply #8 on: 30 March 2007, 21:41:46 »
As an aside, how often are you changing coolant, and what are you using?
Martin_1962
Re: Cool running
« Reply #9 on: 30 March 2007, 21:45:06 »
Not often - not since I dumped the system last year!!
Antifreeze what ever is handy
Last was one at Tesco because the low water came on (got a slow leak with no obvious location - had it for ages now)
Martin_1962
Re: Cool running
« Reply #10 on: 30 March 2007, 21:52:18 »
Definately not a bad earth - gradual change, heater heats up quickly - up to 24deg within 90 seconds (thats my change over temp), I will check top hose tomorrow but will probably get a thermostat anyway.
Where is the thermostat on the V6?
Re: Cool running
« Reply #11 on: 30 March 2007, 22:01:13 »
Stat is in valley, right at front.  Bit of a pig, but sweettalk JamesV6CDX who has done one recently....  ....just don't say he is too young to work on your car  :-X
Martin_1962
Re: Cool running
« Reply #12 on: 30 March 2007, 22:30:01 »
Hmm good idea! ;D :y
If he still wants gassing I'd help with that!
Re: Cool running
« Reply #13 on: 30 March 2007, 22:44:51 »
I think the mileage he is now doing makes LPG less attractive...
Martin_1962
Re: Cool running
« Reply #14 on: 30 March 2007, 23:35:30 »
fairy nuff!
He might as well pass the OMVL kit on to Tunny then
