Author Topic: Urgent torque setting needed  (Read 3322 times)
  • Online Online
« on: 31 March 2007, 14:39:19 »
V6, head to block, sequence and torque / angles needed... on my way there as soon as I find out!!!
  • Online Online
Re: Urgent torque setting needed
« Reply #1 on: 31 March 2007, 14:57:27 »
Is Anyone with Haynes online?
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 31 March 2007, 15:02:56 »
give me two minutes till i fetch mine.. :y
  • Online Online
« Reply #3 on: 31 March 2007, 15:05:28 »
Good man :)
Markie
« Reply #4 on: 31 March 2007, 15:07:12 »
cylinder head bolts i take it?
  • Online Online
« Reply #5 on: 31 March 2007, 15:08:12 »
Please....
« Reply #6 on: 31 March 2007, 15:11:18 »
25Nm +90 deg +90 deg +90 deg + 15deg.....  (the 15deg is optional....)
Bring it down in stages (i.e. all to 25Nm then all plus 1 90 deg etc) working from inner bolts to outer.....
use lots of grease on the top and bottom side of the head bolt washer......and a very light oil on the threads.....not much though, you dont want them to hydraulic....
Markie
« Reply #7 on: 31 March 2007, 15:11:22 »
quoted......haynes
cylinder head bolts 25nm / 18 lbf ft stage 1
angle tighten a further 90degrees stage 2
angle tighten a further 90degrees stage 3
angle tighten a further 90 degrees stage 4
angle tghten a frther 15 degrees stage 5
let me see if i can find sequence  :y
« Reply #8 on: 31 March 2007, 15:13:55 »
6 1 3 7
o o o o
o o o o
8 4 2 5
« Reply #9 on: 31 March 2007, 15:14:48 »
As a tip.....put a piece of kitchen roll in each bolt hole before starting each stage of tightening.......remove it as you tighten the bolt....that way you wont miss one.......then place them all back in again before the next stage....
« Last Edit: 31 March 2007, 18:13:15 by Mark »
Markie
« Reply #10 on: 31 March 2007, 15:21:10 »
o o o o
o o o o
8 4 2 5
jeez the mans like lightening   :y ;D
« Reply #11 on: 31 March 2007, 15:26:11 »
I dont have to look it up.......
Markie
« Reply #12 on: 31 March 2007, 15:58:53 »
i knew that  :y
ians
  • Reading
« Reply #13 on: 31 March 2007, 17:38:12 »
sad use of brain cells..
and won't that kitten roll get fur everywhere? ;D ;D
