Author Topic: THE DREADED LEAKY CAM COVERS..V6  (Read 6888 times)
amba
  • Medway towns
    • German V6
« on: 28 March 2007, 15:44:29 »
Can any body give me some advise regarding the dreaded cam covers ..just had both sets of gaskets replaced together with "o"rings and the vauxhall sealant,by my local mechanic..who does a good job....after less than a week am getting the kebab shop smell again and smoke appearing  from under the bonnet on drivers side..you can just see a very small trace of oil which seems to be dripping onto the manifold and burning off....this was the very problem I had when car went to garage.....it has now been suggested that the rocker covers could be warped and will need to be replaced...my garage man has said he will do the work free of charge ..but I must buy the covers as he could not be liable for them...when I rang Vauxhall they have quoted £70=00 each side plus vat...not cheap ahh....could anybody throw some light onto the reality that these do warp and is the price correct for what seems to be just plastic...or is there a cheaper way out of this as second hand would seem pointless with the work involved to find still leaking..thanks guys and await any help and advise...andrew(mobile kebab shop )
rpont
  • Tadcaster
Re: THE DREADED LEAKY CAM COVERS..V6
« Reply #1 on: 28 March 2007, 16:11:28 »
Two questions.
Was the complete breather system cleaned out? If it's still blocked the pressures will build up and blow the gaskets again. If not cleaning them and reseating the gaskets should solve it.
Were genuine Vauxhall gaskets used? Only the genuine ones seem to last but even they should have lasted longer if the breathers were cleaned.
« Last Edit: 28 March 2007, 16:12:17 by rpont »
hotel21
  • The Kingdom of Fife
« Reply #2 on: 28 March 2007, 16:12:12 »
First question - genuine VX gaskets or some from E-bay or elsewhere?  If genuine VX gaskets, possible that covers have warped, as long as the mechanic as as competent as you hope.
If they are aftermarket, non VX gaskets, they are harder rubber/plastic and are very prone to leaking, especially if the proper sealant is not used.
Second - breathers.  If the breather system is blocked (look for the howtoo) then all that happens is the engine overpressurises and the pressure has to go at the weakes spot, ie the cam cover gaskets.
Clean the breahter system first, then get proper VX gaskets.  Get the mechanic to replace both (as he is doing it for free) but take along a copy of the howtoo so that he (or she) can see whats advised as regards sealant etc.
hotel21
« Reply #3 on: 28 March 2007, 16:12:48 »
Rpont - I must type faster....   ;D
amba
  • Medway towns
    • German V6
« Reply #4 on: 28 March 2007, 16:16:55 »
Thanks for reply.
Yes..the breathers were totally cleaned..they actually had very little muck in them..as oil has been replaced regularly and car does not stand around for long..as I drive over 700 miles a week.
The gaskets were original vauxhall parts bought from main dealer with part no,s checked at counter.
The problem has now been suggested as "warped "rocker covers..does this happen as they are only plastic?and if so is there a better part to get than the same plastic part??
Thanks...andrew
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #5 on: 28 March 2007, 17:42:26 »
Thanks for reply.
Thanks...andrew
Andrew,
Phone autovaux, they supplied me new cam covers for 57 + vat each, this INCLUDES new gaskets - all are genuine GM parts.
As for changing from plastic, I believe it is possible to get the metal ones from a vectra with the same x25xe / x30xe engine - however something needs to be done about the oil filler neck as it wont just go on (different place on the vectra, it doesn't have a neck).  Someone else should be able to confirm what it is you do to get the vectra ones on.  If I get trouble from mine again this is what I want to do where possible..
Cheers,
Chris.
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #6 on: 28 March 2007, 18:35:31 »
Thanks for reply.
Thanks...andrew
Different gaskets too on Veccy, so I'm told...DC
Andrew,
Cheers,
Chris.
Different gaskets too on Veccy, so I'm told...DC[size=14][/size]
« Last Edit: 28 March 2007, 18:37:27 by dave_c »
Admin
« Reply #7 on: 28 March 2007, 19:15:55 »
Probably a warped cover.
Gaskets should be ok ater a week. I would clean and re-use with replacement covers.
Check the general chat. James V6 CDX is selling a pair of perfectly good (he won't sell anything duff) covers for dirt cheap money.
Oh, and make sure the complete intake and breather system is cleaned!
The Administrator.
amba
  • Medway towns
    • German V6
« Reply #8 on: 28 March 2007, 21:59:06 »
Thanks for advise guys..will see if I acn track down James as might get a good deal on some second use ones....also will try autovaux as would prefer to go new then be sure as pain keep having car off road....cheers for good advise about vectra metal ones....think I will opt for like for like ....not every omega has leaky rocker gaskets???my last beast cdx 2.5 on a S plate had passed 225000 miles before the cost of repair out weighed my love of her so sadly she is no more..another tale another day..once again thanks for advise...andrew
ians
  • Reading
« Reply #9 on: 29 March 2007, 07:57:33 »
You say you can see oil -is that actually at the camcover joint?
The residual oil will take a while to burn off (not long at 700 miles a week though), but might be worth giving it a while to eliminate that.
rpont
  • Tadcaster
« Reply #10 on: 29 March 2007, 09:38:01 »
..or me slower  ;D
amba
  • Medway towns
    • German V6
« Reply #11 on: 29 March 2007, 20:50:18 »
oil is new as i wipe it off every morning and by the time i come off motorway slip after about 50 miles at 70mph ish smoke appears and smells !!is it possible for the rocker covers to warp??seems strange..still awaiting any offers of covers to buy.thanks
ians
  • Reading
« Reply #12 on: 29 March 2007, 23:08:27 »
I think they do warp. They are made of plastic and susceptible to overtightening (perhaps by previous owner/mechanic trying to stop the leak..)
Is there new oil in your plug holes?
When you say you did the breathers did this include the boxes at the back,  three hoses and the Ecotec bit?
amba
  • Medway towns
    • German V6
« Reply #13 on: 30 March 2007, 09:59:57 »
No oil in plug holes..just the slightest weep on drivers side right at the back and falling on large chrome pipe..then burning off..passenger side is similar position again at back but not the same burning..expect the exhaust doesn,t rin that way..when they were replaced some 12 days ago and 1100 miles oil and filter were both replaced so oil is still very clean.....I was assured that whilst all parts were removed all pipes etc were cleaned,so as no expert must rely on my mechanics honesty..any way seems strange if he didnt do job correctly as he has now said he will do it all again f.o.c..but did suggest that it may be the covers which are warped and if i bought those he would replace them at same time.....going back to these breathers etc..as i am no mechanic but can follow instructions is this a job that could be done by a total novice,as you have now set my mind thinking that another week/another days lost work/the cost of the covers which might be needed or not...still to find a leak..or should i just tell him to do the breathers as per the instructions i found on the forum??..all these decisions!!!and all i want is no oil smell.
« Reply #14 on: 30 March 2007, 11:01:18 »
Your mechanic didn't overtighten the cam covers? 8Nm, no more.
Also black sealant in the correct places.
« Last Edit: 30 March 2007, 11:01:44 by TheBoy »
