It did look like this!
Started by Taxi_Driver, 03 April 2007, 14:48:15
Taxi_Driver
What would I look for in a Spanish shop/garage as a carb cleaner? Is there a UK brand you can get in Halfords etc?
The stuff i used/have is by Wynns.....and funnily enough its called 'fuel injection intake and carb cleaner'  ;) bought from Halfords
Auto Addict
QuoteThanks guys  :y
Its been a job ive been putting off for a while.....ive only been up the road in it since...but it did seem to have more of a response (even on lpg!) tho may have been my imagination... :-/
I'll have to see what its like in the morning.....its suppose to be chilly tonight....and for a while its been missing when it first switches to lpg in the mornings when its cold out.
After you've cleaned it out, and left it overnight, especially if it's a chilly night, the car will probably not start, if it does start you will notice a major decrease in performance, and it probably won't run at all on gas at all.
It better do.....or else it will get a damm good thrashing.....John Cleese Style  ;D
I suggest you leave it for about 48 hours before you try to start it again.
Im intriegued now AA.....so why do you think it wont start in the morning?
The Carb Cleaner, if left overnight, especially on dual fuel systems, will form an anti start film in the injectors, this eventually clears if left for 48 hours.
I like red cars
Taxi_Driver
#17
Ahhh but ive run it since.....went to the docs in it.....so any carb cleaner left should have evapourated by now  ;)
Dave-C
QuoteI can't see any difference in the photos. Only kidding.
Mine is worse than yours was to start after I cleaned it! Mind you I had none of this "carb cleaner" so had to use petrol and a rag etc.
Years ago when I was into Cooper S's, I got given a gallon of something like CarboTetro something. It was a clear liquid that was absolutely brilliant for cleaning bearing surfaces etc. Probably illegal nowadays.
Try some CHILLI SAUCE!  That'll disolve anything!
DC
Chopsdad
Wynns is sold in Halfords in a purple can - £5.
Well done TD - I hope you lubed it with 3in1 as in AA's guide or it may stick open at idle.  :y
Hillper
That would have been Carbontetrachloride or dry cleaning solution Olive.  It could dissolve your brain at 50 paces.
Not easily available now.  I used to like pouring it onto my hands and watching it boil and evapourate.
Mods.  'Hillper boot release'.  Dimming mirror.  Cruise control. Rear parking sensors.  Becker/Rockford Fosgate/Infinity/Alpine audio.
Auto Addict
QuoteAhhh but ive run it since.....went to the docs in it.....so any carb cleaner left should have evapourated by now  ;)
It still won't start in the morning.....
I like red cars
QuoteI used to like pouring it onto my hands and watching it boil and evapourate.
There are therapy workshops for such disorders......
Olympia5776
Carbontetrochloryne. :)
Used to come in aerosol cans way back when I was an apprentice in the Steel Industry.There was a brand name but can't think of it .Absolutley brilliant stuff could be used to degrease a sump to spot cleaning a carpet !!!Come to think of it is it not still used in dry cleaning ? But you're probably right that you'd be remanded in custody if you were caught in possesion . ::)
Taxi_Driver
Cheers.....I did use a spot of 3in1.....however on 2.2's possibly all DBW's the butterfly does stay open a tad in the idle position.  :y
bogit
QuoteCarbontetrochloryne. :)
when i was at school,did my work experiance in an airplane brake and wheel refurbishing shop.
used to use an aresol called skyrol for cleaning the carbon off the brake drums and wheels.
now that stuff was evil. use in a well ventilated room ? if used outside the corner shop owner used to complain about the fumes 3 streets away,
happy days,
and then we learn what these various chemicals actualy do to our bodys.  :-[
dash bulbs replaced,ecc sorted,atf to go, door blowers-maybe
Used to come in aerosol cans way back when I was an apprentice in the Steel Industry.There was a brand name but can't think of it .......
Ahh! CTC. Used to be widely used in the Navy at sea. It was wonderful using it in the confined spaces of a ship!?!?
Also when I first started at my last job in 1990 we used to get it in 5 gallon drums under the name of Jenclean(sp?), great for cleaning up oil splills.  :-?
Auto Addict
They do.
I like red cars
Taxi_Driver
It did 'on the button' and ran on lpg  :)
Sooo.....you saying yours didnt then AA?
Auto Addict
Just trying to cause you a restless night TD ;) ;D
I like red cars
