Author Topic: Some daft questions!?!  (Read 2149 times)
Arrolman
  • Renfrew,Scotland
« on: 05 April 2007, 19:40:50 »
Hi,
How many brake pads are on each wheel? 2 or 1? I thought it was two but I have got 4 brake pads too do the car, from the main dealers.
Also, My traction control and ABS don't seem to work, both interlinked aren't they? Worked fine till I got spark plugs etc changed, had the warning lights stay on on drive home, but when I switched off and back on they went off, no problems reading on MID or with warning lights? Loose plug or something more expensive?
Cheers,
Iain
Looking to win the lottery..........
philayl
  • Wirral, Merseyide
Re: Some daft questions!?!
« Reply #1 on: 05 April 2007, 19:43:23 »
Two pads to each wheel, eight in total, sorry can't help with your other problem.
« Reply #2 on: 05 April 2007, 19:56:22 »
2 per wheel, pads given are for front only.
You will also need 2 brake sensors, 1 each side for the front (none on rear), only one brake sensor is required if car is post 2001.
Rear wheels use a different size pad iic...
« Reply #3 on: 05 April 2007, 20:44:30 »
Rear pads are completely different ;)
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #4 on: 05 April 2007, 21:27:19 »
Plus set of brake shoes if needed for the handbrake which operates on a drum system
