Author Topic: uncomfortable seats  (Read 7229 times)
Re: uncomfortable seats
« Reply #15 on: 06 April 2007, 22:19:56 »
All Omega Sports Leather is black.
Fudgeknuckle!  >:(
I win
 ::) ;D ;D
amba
  • Medway towns
    • German V6
« Reply #16 on: 06 April 2007, 22:37:55 »
Back to these seats..am i right then that there are 2 types?mv6 sports seats and recaro?..mine a black leather with thigh pull out supports..they have side air bags and solid headrests..are only adjustable electrically up/down..have pitch adjuster lever..so would these have been a factory extra or have these been retro fitted...I am sure it is not just me but they don,t seem that comfortable..yes i am a little wider than i should be but not so that outside the range of normal...so might be open to a swap..but as all door cards and rears are black leather,would need to match
theolodian
  • I need a new avatar.
« Reply #17 on: 06 April 2007, 22:41:07 »
I think Pete will be on you.
Non-memory seats have the lever that you described.
« Reply #18 on: 06 April 2007, 23:03:26 »
Fudgeknuckle!  >:(
Tin of spray paint should sort that  ;) ;D
« Reply #19 on: 06 April 2007, 23:16:40 »
The Sports seats (recaros) were an option on Elites. You lost all the memory stuff and fancy mirror though...
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #20 on: 06 April 2007, 23:25:57 »
I personally found the mini-facelift non-sport leather seats uncomfortable after about 2 hours' driving. For that reason I swapped for a facelift model - the seats in which suit my shape much better. Drove for over 4 hours non-stop in that - no probs whatsoever ... the trouble is that you really need to go on a drive for that sort of time and distance before you know if the seats are right for you ...
« Reply #21 on: 07 April 2007, 01:56:33 »
I had the MV6 with black Recaro leather and I thought they were very comfy and im 16 stone and yes I would love to swap for mine :y
bogit
  • Northampton
  • yes i do know its missing 2 wheels :)
« Reply #22 on: 07 April 2007, 05:32:29 »
16 stone,,,,,,light weight lol no rearly u are compared to me lol.
6ft 2 20 stone on a bad day and I found the sports seats nmbed my legs when I first got the car and drove it with the seat base tilted back.put it flat,and its all good now.
my mates old recarososports seats in his old astra sport.broke the sidebolsters ,arse was just a tad to wide for them lol.mind u I did spend a lot of time in it.
try with the seat flat and thigh support in.works for me.
dash bulbs replaced,ecc sorted,atf to go, door blowers-maybe
amba
  • Medway towns
    • German V6
« Reply #23 on: 07 April 2007, 08:07:04 »
Thanks guys...will try flat position with leg support in ( as the actress.......) if that does not work any better today will go and get a piece of industrial cushion foam for hole seat pad and give that a go..trouble is might be touching the roof lining then...if all else fails and ny arse is still numb I will be on to Pete,and if we are not at the other ends of the world perhaps we could do a deal..what happens about the air bag and sensors when you take seats out ??
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #24 on: 07 April 2007, 22:26:42 »
I about 15 stone ;) and find the seats really comfy and i don't slide around either, Tunnie is a slim guy and may rattle around a bit ;D XX so maybe the Sports seats are for the fuller man like us Pete ;D
« Reply #25 on: 08 April 2007, 00:32:50 »
The fuller man  ;D my misses says im fat but my reply is it takes a big hammer to knock a big nail in ;)
« Reply #26 on: 08 April 2007, 08:43:56 »
Spend some time setting them........you need to set the distance from the pedals correctly and then adjust the seat tilt so that you have even presure across the base of your legs......
Then set the back rest so with your back against the seat back you can rest the base of your hands on the steering wheel.....
This will probably feel uncomfortable for a while but, you soon get used to it....
amba
  • Medway towns
    • German V6
« Reply #27 on: 08 April 2007, 09:52:03 »
Seem to be better yesterday with a cushion on seat pad..seem that the side bolsters wedge you in ..will give it a proper adjustment today as going to France on Wednesday for couple of days and about 1500 miles to drive...so either eat no easter eggs today/or go on a crash diet..thanks for all suggestions ..will keep you posted as still may consider a swap..Happy easter to all...Andrew
