Author Topic: what are those 4 beeps???????  (Read 4848 times)
wakeyomega
  • Wakefield
« on: 07 April 2007, 19:45:21 »
Now I've got the grease off my hands from the HBV change, (and changed my pants from the close call with the radiator tap) - here's a question thats has bothered me from day one of owning this car , nearly seven years ago. On occasions when I turn off the ignition I get 4 'beeps', which I now believe come from the horn sited underneath the scuttle on the drivers side. It usually happens when I have turned off the ignition and removed the key in one swift movement. It certainly never happens all the time, quite the opposite. I'm sure its some part of the system telling me off.
Any ideas
Thanks Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
Taxi_Driver
Re: what are those 4 beeps???????
« Reply #1 on: 07 April 2007, 19:50:51 »
It usually means the battery in the power sounder alarm is fubared.....vx dealer will try to sell you complete new replacement.....but it can be taken apart and replacement batteries fitted  :y
STMO123
« Reply #2 on: 07 April 2007, 19:52:32 »
The dreaded 4 beeps Pat. It means that the batteries in your power sounder have had it. We've had this question a few times on the forum, I'll see if i can find the appropriate thread and post back
« Reply #3 on: 07 April 2007, 19:53:59 »
yup backup alarm module is on its last legs, its under the scuttle on the drivers side.
Remove and replace battery, or a much easier option is just unplug it!  ;)
omegalyn
« Reply #4 on: 07 April 2007, 20:46:09 »
I have had the same beeps since I've had my 2.0 gls, but I thought it had something to do with the Sony sound system.  what dose this battery thing look like, and what is it for!!!
Omegalyn
« Last Edit: 07 April 2007, 20:47:06 by omegalyn »
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
« Reply #5 on: 07 April 2007, 21:06:18 »
Any ideas
Thanks Pat
It sounds like an intermitent fault and if it's been happening every now and again for seven years, it sounds more like a loose or semi-not-happy connection.
Surely if it was the batteries giving up it would have died years ago!
It can be removed you know!   ;)
HTH
Taxi_Driver
« Reply #6 on: 08 April 2007, 07:46:02 »
Omegalyn
Some Sony car stereos do beep when you turn the ign off.....its a warning to remove the front panel off the stereo.....so dont get it confused with this.
If the power sounder goes off....this is a warning that the car battery has been disconected...and therefore disabling the main car alarm
You can tell if its the Sony stereo beeping.....coz the beeps come from the front speakers  :y
omegalyn
« Reply #7 on: 08 April 2007, 20:39:42 »
Thanks TD, yes my beeps do come from the front speekers, so its a sony thing for me.
Thanks.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #8 on: 08 April 2007, 21:24:18 »
Thanks.
Result :y
« Reply #9 on: 08 April 2007, 21:42:57 »
Thanks.
That would annoy me.
Yet another reason, as if I needed more, to avoid Sony junk.
Taxi_Driver
« Reply #10 on: 08 April 2007, 21:48:25 »
Thanks.
Thats the reason......to annoy you...so you do remove the front panel off the stereo  ;D
« Reply #11 on: 08 April 2007, 21:58:42 »
Thanks.
Sammy Sledge would sort the beeping  >:(
Taxi_Driver
« Reply #12 on: 08 April 2007, 22:08:20 »
Thanks.
If you hadnt been careless and lost him  ::)
« Reply #13 on: 08 April 2007, 22:19:29 »
Thanks.
But Percy Pick is a suitable alternative....
Taxi_Driver
« Reply #14 on: 08 April 2007, 22:49:34 »
Thanks.
You sure you havent lost him too  ;D
