Author Topic: v6 multi ram connector  (Read 2703 times)
amba
  • Medway towns
    • German V6
« on: 08 April 2007, 17:25:56 »
Thought I had got multiram plug sorted,but driving home this afternoon eml came on again....after checking it seemed that the multiram connector that I thought I had pushed on had fallen off....as the engine was hot decided to drive home slowly and let it cool down and then try and fit it back again....my question is ?if the car runs fine with it disconnected what is its purpose??and will driving the car with it disconnected have any detrimental effect???just I am no mechanic and as car is off to mechanics on Tuesday for the third set of cam cover gaskets and new covers could I leave it until then as it seems that it might be easier for him to refit it when partially dismanteld
STMO123
Re: v6 multi ram connector
« Reply #1 on: 08 April 2007, 17:56:36 »
I take it you're talking about the front multi ram connector on the intake pipes at the front of the engine. If so, it will do no harm to leave it until Tuesday. Some omegas hardly ever have them working properly anyway, due to Vx technicians not knowing how to put the vac pipes back where they came from :D
amba
  • Medway towns
    • German V6
« Reply #2 on: 08 April 2007, 18:17:41 »
No..its the plug at the back of engine on nearside?just by the hbv..black plastic plug with wire retainer around it ..have seen it is just hanging there
STMO123
« Reply #3 on: 08 April 2007, 18:31:10 »
Its the one for the rear multi ram then. Either way, it will be OK to drive, just a bit down on power at the top end.
amba
  • Medway towns
    • German V6
« Reply #4 on: 08 April 2007, 18:35:05 »
Thanks alot for putting my mind at rest..will get it sorted tuesday..then hopefully it will run fine and stop smelling like a kebab shop and avoid everybody thinking I am on fire when pull up at traffic lights.
STMO123
« Reply #5 on: 08 April 2007, 18:35:43 »
 ;D ;D :y
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #6 on: 08 April 2007, 20:02:53 »
the plug should have a metal spring to secure it in place, this might have got lost (or maybe the plug has got damaged) - hence why it keeps falling off ... if it's got the spring, when fitting you need to push it home until it clicks into place ...
STMO123
« Reply #7 on: 08 April 2007, 20:10:39 »
The spring on my front connector flew off somewhere when I changed the solenoid (after the garage had broken it and GLUED it back together) so now mine has a small dab of bostik holding it in position :-[
amba
  • Medway towns
    • German V6
« Reply #8 on: 08 April 2007, 22:39:00 »
All now sorted..been out with torch and found plug was off..as suspected...as engine was now cold made job easier..pushed it in to socket..got a nice "click"sound so expect that was problem from when cam gaskets were last done..started engine and no eml..so all is now well..lets hope cam covers and gaskets sort out oil leak on tuesday
sounds2k
« Reply #9 on: 09 April 2007, 08:57:35 »
job's a good 'un !!
let's hope 3rd time lucky on the cam covers & gaskets  :y
amba
  • Medway towns
    • German V6
« Reply #10 on: 09 April 2007, 09:03:54 »
I tell you ..if they leak or even slightly smell like bacon frying after tomorrow  you might well see on the news....gillingham mechanic severely injured by angry omega driver armed with rocker cover ..watch this space.???
STMO123
« Reply #11 on: 09 April 2007, 09:56:03 »
I take it you've had the breathers cleaned out?
amba
  • Medway towns
    • German V6
« Reply #12 on: 09 April 2007, 10:38:10 »
The last invoice stated that breathers had been cleaned/gaskets o rings replaced with new/oil and filter changed....in fairness to the guy he thinks the rocker covers could be warped?? so said if i get some new/secondhand ones  I supply new gaskets etc he will do the job again FOC.so will give him the print out from forum on "breather cleaning"and ask that he follows it to the letter..have used him for couple of years and seems realiable and fair...so hay..hoo..fingers crossed
STMO123
« Reply #13 on: 09 April 2007, 11:32:56 »
I think JamesV6CDX has a set of covers. £10 IIRC
« Last Edit: 09 April 2007, 11:35:09 by STMO123 »
STMO123
« Reply #14 on: 09 April 2007, 11:36:41 »
.....and remember, genuine Vx gaskets :y
