Author Topic: Water Leak  (Read 2682 times)
Spam95
  • Lancashire
Water Leak
« on: 08 April 2007, 13:13:24 »
On the way to work yesterday I got a 'Coolant Level' warning and as I stopped, I saw a gush of steam from the bonnet just in front of the drivers position. When I opened the bonnet I saw water dripping from onto the motor from the back right upper side of the engine where there are two pipes and a valvey looking thing. Of course I can't see exactly where it is coming from but I wondered if there was any known fault in this area.
Also, is it a big job to get that black bulkhead off as it is seriously obstructing the view of theis area.
Yours heatedly
Chris
Lots of things niggling me
Re: Water Leak
« Reply #1 on: 08 April 2007, 13:16:32 »
Sounds like the Heater Bypass Valve mate
£25 ish from the dealer, and 30 mins to fit yourself - easy DIY job
Access is much improved with scuttle off
Spam95
  • Lancashire
Re: Water Leak
« Reply #2 on: 08 April 2007, 13:21:07 »
Boy that was quick. Is this a common fault? FIO the leak is just behind the 2 pipes with the yellow 'FUEL' stickers on.
Chris
Re: Water Leak
« Reply #3 on: 08 April 2007, 13:39:48 »
The HBV is just behind that area - by the bulkhead. It has two pipes going in on one side, and one pipe on the other.
Quite a common fault, but an easy fix.
Spam95
  • Lancashire
Re: Water Leak
« Reply #4 on: 08 April 2007, 13:45:33 »
James
Thank you very much. you've set my mind at rest, so much so that I'll think I'll open a bottle of Easter beer!!!
However, I won't try to fix it myself, as I have no skills at all. I'll take it to the dealer probably on tuesday.
Once again thanks
Chris
Re: Water Leak
« Reply #5 on: 08 April 2007, 14:14:00 »
James
Once again thanks
Chris
If you were anywhere near me I'd help, it's really not a hard job...
If having just the HBV done at a dealership/garage... make sure they don't charge you any more than 30 mins labour... 60 mins top whack... if they do, they're having a laff....
Once scuttle is off, which is childs play - 3 clips and 3 hoses.. that's all there is to this job!
« Last Edit: 08 April 2007, 14:14:44 by JamesV6CDX »
Spam95
  • Lancashire
Re: Water Leak
« Reply #6 on: 08 April 2007, 14:46:30 »
Are there any private Omega privateers who could do this jo near me in Lancashire? I would like to stay away from the dealers if I can...cos I'm poor!!!
CD
Re: Water Leak
« Reply #7 on: 08 April 2007, 17:19:36 »
CD
Lancs is a big place. If you're near me in Bury though I'll gladly (help you) do it.
wakeyomega
  • Wakefield
Re: Water Leak
« Reply #8 on: 09 April 2007, 19:38:51 »
To give you a comparison, I got a quote for this job on Saturday at a Vauxhall dealer - £175 inc VAT and parts. I did it my self (first ever task on the Omega) and it cost me £23 .50 for the HBV (from AutoVaux which luckily is based in wakefield where I live).
Good Luck
Pat
Remember, if you ever need a helping hand, you'll find one at the end of your arm
Re: Water Leak
« Reply #9 on: 09 April 2007, 20:06:30 »
Good Luck
Pat
So that's £150 (ish) for labour! Even you say £75 an hour, that gives 'em 2 hours to do it!! :o  Thieving barstewards! >:(
Re: Water Leak
« Reply #10 on: 09 April 2007, 21:15:22 »
Good Luck
Pat
Stealers are about £90 to £100 per hour here....
Re: Water Leak
« Reply #11 on: 10 April 2007, 01:34:35 »
£100 an hour still gives them an hour & a half to do it. Wth all the practice they should be able to do it in less than an hour! I wonder what TIS suggests!  ::)
Re: Water Leak
« Reply #12 on: 10 April 2007, 09:56:40 »
0.7 for valve replacement on v6 (0.9 on DBW units), plus bleed and refill coolant.
