Author Topic: Thermostat change  (Read 3291 times)
Martin_1962
Thermostat change
« on: 10 April 2007, 19:52:46 »
Oh well I have a new one - now where is the old one, and how easy is it to change?
Re: Thermostat change
« Reply #1 on: 10 April 2007, 20:11:53 »
In the valley, at the front.  Plenum, intakes, injectors rails off and you can see it...
Markjay
  • London
« Reply #2 on: 10 April 2007, 20:30:29 »
Martin, HTH (no credit claimed for the pictures...):
Alas, no more Omegas....
Markjay
  • London
« Reply #3 on: 10 April 2007, 20:32:26 »
Incidentally, I just realised the camcovers on the top pic are odd... they seem to be metallic, or perhaps someone painted then silver?  :o
« Reply #4 on: 10 April 2007, 20:57:33 »
They look like vectra covers..
« Reply #5 on: 10 April 2007, 21:27:47 »
Veccy ones ;)
Martin_1962
« Reply #6 on: 10 April 2007, 23:32:05 »
Oh - that's a bugger to change - wish I knew when I fitted the cut wiring.
Are there any bits I need apart from the L pipe, O ring and thermostat?
Just hope I can get the rail out as I can't unplug the injectors (Romano leads)
Martin_1962
« Reply #7 on: 10 April 2007, 23:42:02 »
Oh thanks for the pictures, looks like a job for a day when I am not busy!
Markjay
  • London
« Reply #8 on: 10 April 2007, 23:49:19 »
Veccy ones ;)
Ahha... that explains the filler cap at the far end then...
Markjay
  • London
« Reply #9 on: 10 April 2007, 23:51:22 »
Looking at the bottom pic, I can now see clearly the metal breather box at the back of the engine... it seem to be mounted with for bolts at the base. Good job I didn't try to take it of then.....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #10 on: 11 April 2007, 00:05:16 »
can be a swine to release stat housing from cooland pipe  >:(
« Reply #11 on: 11 April 2007, 01:30:11 »
Martin, it's not an awful job, but nimble fingers help!
If you need a hand (literally!) give me a yell, I'm only half hour away :)
Martin_1962
« Reply #12 on: 11 April 2007, 11:52:15 »
I'll most probably be doing it Saturday afternoon (not sure yet), I wouldn't mind a hand - if only to a todo guide with pictures!
I am also expecting a nightmare with the injectors as the cut cables do not want to unplug (they don't have the release bit the car loom has), so it has to come out as one big lump.
ClarCE
  • Newbury, Berks
  • Cam Covers x 5
« Reply #13 on: 11 April 2007, 12:00:49 »
I'll most probably be doing it Saturday afternoon...
Me 2, expect threads prefixed with 'urgent' !
So Far - :: Re-Finished Elite Wheels :: Black Leather Interior :: 3.0 Cams :: Chipped (REMOVED, EBAY SHI*E) :: Facelift Skirts ::
To Do   - :: Facelift Rear Bumper, Door Mouldings :: Irsmsher Front Air Da
Martin_1962
« Reply #14 on: 12 April 2007, 10:06:11 »
Wel Sue has OKed Saturday afternoon - doing town in the morning Jack broke his glasses.
So if you can help James it would be appreciated.
It will be interesting to see if my plenum removal pipe routing does actually help!!
