Author Topic: omega front fogs  (Read 2683 times)
morris
omega front fogs
« on: 10 April 2007, 11:04:59 »
hi,
have fitted front fogs to my superb omega, and found connecting cables ok at front bumper. Changed light switch box for it to take front fog switch and hey presto power to switch when activated, but front fogs do not come on.
Checked fuse 16 as told by my omega book and no fuse, inserted fuse and still no fog lights what do i need to do now please anyone know or have added front fogs in the past
Steve
STMO123
Re: omega front fogs
« Reply #1 on: 10 April 2007, 12:58:28 »
You say you have power TO the switch, do you have power on the other side of the switch?
ians
  • Reading
« Reply #2 on: 10 April 2007, 18:03:51 »
Did you switch the headlights on?
STMO123
« Reply #3 on: 10 April 2007, 18:06:47 »
Good point :y
morris
« Reply #4 on: 11 April 2007, 11:15:39 »
yeah rear fogs only work with headlights on, so was expecting to see front fogs lit when headlights on
morris
« Reply #5 on: 11 April 2007, 11:18:31 »
according to wiring diagram front fogs meet fuse 16 and then to light switch on connector 5 at the rear of the switch,
have checked this and even teed in a second spur direct to to fogs and still nothing
nixoro
  • Hitchin, Herts
« Reply #6 on: 11 April 2007, 16:13:14 »
Have you swapped the bulbs at all, perhaps they are dead, worth checking :y
Are all the connections nice and snug :question
« Reply #7 on: 11 April 2007, 22:09:48 »
Have you checked for volts with the fog lights turned on at F16 and the fog lamp bulbs....
Its a case of start at the switch measuring for volts, then the fuse and then the lamps, use a body 0V point at all times....then check the fog light 0v connection to.....
Neil
« Reply #8 on: 12 April 2007, 14:58:17 »
Isn't there a relay that operates the front fogs?  If so firstly is it actually there, and secondly is it working?
