Author Topic: water leak?  (Read 2396 times)
bear33
  • Essex
water leak?
« on: 13 April 2007, 08:07:15 »
I finally got the old girl up and running again last night after 7 weeks not moving. after driving her round for about 30 mins i parked her back up and left the engine running for bout 20 minutes or so to charge the battery up. I noticed water underneath. My mate looked underneath and he said its coming from air conditioning cos it was ice cold. Is this normal?
Cheers
Chris
« Last Edit: 13 April 2007, 08:07:55 by bear33 »
Re: water leak?
« Reply #1 on: 13 April 2007, 08:46:16 »
where was it dripping from?
old cruiser
  • Slough
Re: water leak?
« Reply #2 on: 13 April 2007, 08:46:27 »
If you defineatly had the air-con on during your drive then that is more than likely the condensation from air-con and is perfectly normal, next time you see it just double check it's clear water and not coolant.
Cheers Pete
Re: water leak?
« Reply #3 on: 13 April 2007, 08:49:34 »
Yes, aircon condensate exits through tubes either side of the gearbox....
bear33
  • Essex
Re: water leak?
« Reply #4 on: 13 April 2007, 08:58:38 »
yes its just ice cold clear water. my mate thought that is was where id had the climate on. he said its dispersing the water
Just thought id check
