Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: Help! Project TB2 - Update 6  (Read 17703 times)
Re: Help! Project TB2 - Update 6
« Reply #75 on: 11 April 2007, 21:21:14 »
I suppose its possible that they were all exploded with teh original blocked radiator/ seems strange that you loose minimal coolant with the diesel one tho in spite of its hissing all the time?
I had written the diesel one off as faulty, as it even hisses when you undo the rad drain screw with the cap left on...  :-/
But it does seem to be the best cap  :-/
Maybe you could try my cap(s) and see what you get?
would rather you tried mine!! i have new antifreeze in and dont want to lose it!!! give you a text when i get home tomorrow as i have a short day!!!!
Tomorrow is the one day I am not around (Up at Drax).  Any other day any good?
Omegatoy
  • UK
« Reply #76 on: 11 April 2007, 21:25:14 »
Drat!! forgot about that trip, maybe friday? as i wont be around at teh weekend as will be gving the v6 a hard time at the trackday meet!!!
« Reply #77 on: 11 April 2007, 21:29:04 »
Not sure what time I'll be home, I could drop you a text?
« Reply #78 on: 11 April 2007, 21:39:01 »
Interestingly, Quinton Hazell don't list a cap for 2.5TD in their online catalogue, on 2.0/2.5/3.0  :-?
« Reply #79 on: 11 April 2007, 21:58:06 »
If your popping around to Brackley, can i sneak the Senny in too?  ;)
I hope to have the replacement aux belt by then, although it will be the non air-con belt >:(
Taxi_Driver
« Reply #80 on: 11 April 2007, 22:06:51 »
Think i mentioned in an earlier post about having the correct cap....EPC lists 4 types, one for petrols and 3 different one for diesels.
For the cost of one, they carnt be that much.....I'd suggest getting a new correct cap from vx dealer and trying that.....then you can discount it or even better it might solve it  :y
Or
And maybe a correct coolant bottle while your about it  :-/ (does a new coolant bottle come with the cap?  :-/ )
« Reply #81 on: 11 April 2007, 22:12:13 »
Have you sorted the known problem out yet.....the coolant sensor......its important when fault finding to minimise changes and fix known problems first....
chris-b
  • Wirral
« Reply #82 on: 11 April 2007, 22:20:28 »
Had that problem on my 2.5TD a couple of years ago, it kept going into limp mode, ended up being the water pump after me shelling out about £380 for  new radiator that i didnt need! >:(
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #83 on: 12 April 2007, 11:18:00 »
Taxi Driver, I don't think that new bottles come with the cap.  It is silly not to provide a new cap I think.
« Reply #84 on: 13 April 2007, 15:15:12 »
No, thats this afternoons mission.  As you know, whilst I accept it may create more heat, I am not convinced that this is the issue.
Though you are, of course, correct, and I will have a look at fixing the sensor issue.
« Reply #85 on: 13 April 2007, 21:51:14 »
Pages: 1 2 3 4 5 [6]   Go Up
