Pages: 1 [2] 3  All   Go Down
Author Topic: Secondary air injection pump  (Read 13424 times)
BigCat
  • Battersea
Re: Secondary air injection pump
« Reply #15 on: 14 January 2007, 15:52:33 »
I get a similar sound from mine about ten seconds after I start it up, sounds like a pump or compressor, and runs for about five seconds - is that what you get? I seem to remember reading somewhere on this forum (or the other one) that it's the coolant pump running to prime the heater system.
Dominic
The first 90% of a job takes 90% of the time, the last 10% takes the other 90% of the time.
Paul M
  • Edinburgh
« Reply #16 on: 14 January 2007, 16:03:45 »
No, it lasts a bit longer on mine and also it starts as soon as the engine is started from cold.
« Reply #17 on: 14 January 2007, 16:22:35 »
Paul M, unplug the pump to see if it is that making noise...
JasonH
« Reply #18 on: 14 January 2007, 19:17:03 »
The secondary air pumps runs for a few seconds to a few minutes depending on how cold the engine is when it's started.
Paul M
  • Edinburgh
« Reply #19 on: 15 January 2007, 11:22:19 »
Will disconnect the plug when I get a chance, probably the weekend again.
spiketheskinnydog
  • Mid Glamorgan
« Reply #20 on: 16 January 2007, 14:46:43 »
Mine makes that noise too - just ignore it and tell the neighbours its the supercharger  :y
miked
  • North Yorkshire
« Reply #21 on: 16 January 2007, 16:18:20 »
Do they all have one of these?
I had a V6 Vectra which defiantly had one, very loud on start-up.
Can't say I’ve noticed one on mine, although its only a 4 pot
bestseany
  • Flintshire, North Wales
« Reply #22 on: 16 January 2007, 16:57:35 »
Isn't there a compressor for the self-levelling rear suspension under the wheel arches too? Maybe it's that.
« Reply #23 on: 16 January 2007, 18:59:56 »
Only on the posher models ;), and it will be drivers side...
Paul M
  • Edinburgh
« Reply #24 on: 16 January 2007, 20:50:45 »
Funnily enough mine has self levelling suspension ::)
« Reply #25 on: 16 January 2007, 20:54:33 »
Rare on an MV6, but MV6 (prefacelift) would fit into my description of "posher model" ;D
Paul M
  • Edinburgh
« Reply #26 on: 16 January 2007, 23:52:31 »
 :D yeah I was rather surprised when it was in getting the tracking done, and the guy mentioned the self levelling suspension. I was a bit sceptical until he pointed out the vacuum pipes going into the dampers  ::)
Not that I'm ever likely to use it, never carry anything heavy. Although I guess maybe the dual-fuel tank may be considered heavy lol... wonder if it makes any difference there?
Paul M
  • Edinburgh
« Reply #27 on: 20 January 2007, 17:49:11 »
Disconnected the pump... no change :( So it's not that making the noise, I've reconnected it again.
TBH I was a little sceptical as this noise seems to rise and fall with the revs, although I'm at a loss as to what it can be seeing that it only happens at cold :-/ It's like a "brrrrrrr" kind of noise if that's any help  ;D
wakeyomega
  • Wakefield
« Reply #28 on: 13 April 2007, 21:20:08 »
Sorry for raving this from the grave - but I also get this noise at start up - did you ever find out what it was? (there I was reading through this old thread thinking "any minute now I'll reach the answer", and the thread just stopped! I can't go to bed not knowing, its like reading a good book then finding out that the last page has been torn out and you can't find out who dunnit!  :)
Pat
Omega Hypochondriac
Remember, if you ever need a helping hand, you'll find one at the end of your arm
« Reply #29 on: 13 April 2007, 21:25:37 »
I suspect it wasn't the pump that got disconnected......probably one of the horns...its a common mistake (done it myself!).....it will be the airpump.....try it!
Pages: 1 [2] 3  All   Go Up
