Author Topic: Breathers  (Read 5563 times)
Burti
  • Manchester
Breathers
« on: 12 April 2007, 23:09:00 »
Hi Again,
I am going to change the rocker cover gaskets this weekend, but I read a post some where on here, that when you change your Rocker cover, don't forget to clean the breathers.
This may be a stupid question but is there a good way to clean the breathers and does anyone know how many there is on the 2.5 V6 petrol ?
Thanks again ;)
BrianH
  • Bexley,Kent
Re: Breathers
« Reply #1 on: 12 April 2007, 23:28:30 »
Use this link http://www.omegaowners.com/forum/YaBB.pl?num=1152598350 also lots of other info which helps in guides pictures missing but fairly easy to fillow.
Best of luck
Brian
cdx25
  • Plymouth, UK
Re: Breathers
« Reply #2 on: 12 April 2007, 23:29:05 »
Hi there,
Take a look in the maintenance guides section, on this forum, page 3 or so I think.  Good advice on both gaskets and breathers.
Cheers,
Jon
ians
  • Reading
Re: Breathers
« Reply #3 on: 12 April 2007, 23:32:31 »
There are also instructions for removing the plenum which I found intimidating before reading it.
But its straightforward - just a fair few connections.    Take some photos before you dismantle - will help you get things in the right place when you put it back together.
Cheers
Ian
Markjay
  • London
Re: Breathers
« Reply #4 on: 12 April 2007, 23:37:27 »
Alas, no more Omegas....
ians
  • Reading
Re: Breathers
« Reply #5 on: 12 April 2007, 23:41:00 »
Being a 2.5 yours will be a bit different - just a single black plastic unit under the clipon Ecotec bit, but principle is still the same.   Just be patient and make sure you have plenty of carb cleaner.
Markjay
  • London
Re: Breathers
« Reply #6 on: 12 April 2007, 23:50:58 »
Quite right, I forgot I have the 'long plenum' version... 2.6/3.2L, as well as some 3.0L from around 1999 onwards.
Taxi_Driver
Re: Breathers
« Reply #7 on: 13 April 2007, 09:14:58 »
Nice pics tho MJ  :y
Markjay
  • London
Re: Breathers
« Reply #8 on: 13 April 2007, 09:51:17 »
Nice pics tho MJ  :y
Thank you Sire for your kind words...  ;)
Re: Breathers
« Reply #9 on: 13 April 2007, 19:50:24 »
And, iirc, you have to remove throttle body on short plenums...
Re: Breathers
« Reply #10 on: 13 April 2007, 21:12:45 »
You certianly do.......but it will benefit from a clean anyway....
Ricster
Re: Breathers
« Reply #11 on: 13 April 2007, 21:13:00 »
can some kind soul upload pics to rons guide would make the job a lot easier for the novice ?
Re: Breathers
« Reply #12 on: 13 April 2007, 21:16:11 »
Its on the to do list.....I have a project car on the drive which will have this treatment, pics will be taken in the next week or so, up-loaded and the Maintenance guide edited accordingly......
Ricster
Re: Breathers
« Reply #13 on: 13 April 2007, 21:25:06 »
Nice one :y
Matchless
  • Nottingham
    • A white van
Re: Breathers
« Reply #14 on: 13 April 2007, 23:34:09 »
Need to add the pics of the cam seal drain holes to the camcover guide. they are at work though
