Author Topic: info display and cruise  (Read 4442 times)
gnasha
  • Kettering
« on: 11 April 2007, 19:51:58 »
Right new owner ere got our elite 1997 today and after brake test it comes up low beam then under that FLd/vision any help plz
also i dont think cruise is working i have pressed the l button while doing 50mph took my foot of pedle and it just started slowing down tried a few times but no joy any help or am i doing it wrong
we have 1984 landrover ,1990 rangerover 3.9lpg and 2.5v6 elite 1997 but told it's a 98 spec
Re: info display and cruise
« Reply #1 on: 11 April 2007, 20:34:59 »
Right, the display is saying they is a problem with your HIDs. Only a 97 car should have HIDs  :-/
Is the last letter in your VIN a V or a W?
If you do have HIDs, its telling you the auto levelling of the headlights has failed, normally a sensor problem (1 on NSF wishbone, other on NSR trailing arm).
For the cruise, is it petrol or diesel?  If its a petrol, there is a seperate actuator and second throttle cable - can you check still there?  If diesel, the throttle is electronic.
gnasha
  • Kettering
« Reply #2 on: 11 April 2007, 20:58:44 »
right its petrol and were do i find vin no if its on log book i will have to wait for that 1
« Reply #3 on: 11 April 2007, 21:17:01 »
Passenger side dash, by A post, readable through windscreen.
gnasha
  • Kettering
« Reply #4 on: 11 April 2007, 21:25:44 »
right just looked and the no is wolovbp69w10***** last ones are all nmbers but gives u a clue how it goes
« Reply #5 on: 11 April 2007, 21:31:10 »
98 model year then (mini facelift), so will have HIDs.  Check the sensors on the NSF wishbone and the NSR trialing arm.  Somethings they become unclipped.
gnasha
  • Kettering
« Reply #6 on: 11 April 2007, 21:36:56 »
ok the slip we got says november 97
« Reply #7 on: 11 April 2007, 21:41:13 »
Thats OK, manufacturers tend to release the new 'model year' late in previous year...
gnasha
  • Kettering
« Reply #8 on: 12 April 2007, 12:52:13 »
right looked and second throttle cable connecting to something else there and all conected so were next
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #9 on: 12 April 2007, 15:15:49 »
You'll probably have to wait till tomorrow for an answer, as the 'A' team are on a visit to Drax Power Station today.
I like red cars
jonathanh
  • coventry
« Reply #10 on: 12 April 2007, 16:12:51 »
regarding the cruise, you might want to look at the following thread
http://www.omegaowners.com/forum/YaBB.pl?num=1170492943
on page 2 I posted my pin readouts (admittedly from a manual but you should get the same from an auto except for the clutch switch action.)
Take the cruise multiplug from the top of the actuator and read the pin voltages with a multimeter.  this will confirm whether the unit is getting the correct power feeds.    Also when you are down there, take the cruise cable off the top of the actuator.  You should be able to twist the cable sheath off by 1/4 turn and pull it up by a small amount.  If you do this you should see a yellow canvas strip joining the cable to the mechanism of the actuator.  Without this it will not work
Good luck
« Last Edit: 12 April 2007, 16:13:17 by jonathanh »
philayl
  • Wirral, Merseyide
« Reply #11 on: 12 April 2007, 16:32:21 »
Hi, this might seem like a daft question but you are pressing the right part of the button? It is the dimple at the back of the top button to set the cruise, the hollow at the front is to reduce your speed when cruise is engaged, the ribbed piece below is to disengage the cruise.
gnasha
  • Kettering
« Reply #12 on: 12 April 2007, 20:29:24 »
yep tried that it says that in the manual that i got at least i was doing that part right
« Reply #13 on: 12 April 2007, 22:02:37 »
You mean you read the manual first!!  :-?
        ;D                          ;D
gnasha
  • Kettering
« Reply #14 on: 13 April 2007, 09:46:07 »
        ;D                          ;D
nar not first but did after i could not sus it out not used to all the gadgets yet most i have had on a moter is my 1990 rangerover and that was elec windows lol
Page created in 0.023 seconds with 20 queries.
