Author Topic: info display and cruise  (Read 4445 times)
Re: info display and cruise
« Reply #15 on: 13 April 2007, 19:48:59 »
Worth checking the voltages at the connector as suggested - could still be a number of things, such as wrong brake switch fitted, cable snapped, actuator failed etc...
gnasha
  • Kettering
« Reply #16 on: 13 April 2007, 23:07:07 »
right drove around tonight and the disply warning has gone think it was down to battery condition as i read somewere that bad battery on someone else car caused same prob and after looking into everything he changed battery for new one and that sorted it out so that's that one sorted
now for the cruise found out the yellow strap has snaped so how do i sort that out plz
we have 1984 landrover ,1990 rangerover 3.9lpg and 2.5v6 elite 1997 but told it's a 98 spec
« Reply #17 on: 14 April 2007, 10:23:06 »
The yellow strap thats between the cable and actuator?
New actuator reqd :(.  Well, new to car that is - find a breaker ;)
jonathanh
  • coventry
« Reply #18 on: 14 April 2007, 19:34:34 »
Best place for an actuator is a scappy or fleabay.
Has the strip snapped or has it been dropped back into the actuator?  It is always possible the previous owner was a bit careless....
If the latter then I would take the actuator off and try tipping the actuator upside down to see if it is still in there.  If so  then fish it out with something.  failing that disassemble the actuator and have a fish about that way.
For what its worth, cruise is definitely worth having.  I'm doing over 500 miles this weekend, and would be lost without it
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #19 on: 14 April 2007, 19:45:48 »
Does that mean W is HID & V is not?
« Reply #20 on: 14 April 2007, 20:15:24 »
Yes.
gnasha
  • Kettering
« Reply #21 on: 15 April 2007, 00:34:31 »
defo snapped would av thought u could replace it
it's like saying light bulb gone in house so have to buy new house :o
« Reply #22 on: 15 April 2007, 09:47:31 »
The yellow bit is part of actuator, and non replaceably.  Never known one to snap (the actuator isn't that powerful).  A replacement actuator is not hugely expensive 2nd hand...
gnasha
  • Kettering
« Reply #23 on: 15 April 2007, 18:54:35 »
had a go at diy fix iam british after all after strip down needle and thread came out and after a bit of stiching it looked good for me so rebuilt unit connected all up and tested at25 and worked so put togeather properly and its working fine so job's a gdun will get anouther unit some time but for now will do the job  :)
« Reply #24 on: 15 April 2007, 19:21:21 »
May be worth bidding low on some ebay ones - you may win one cheap, and it will make a good spare. All Omega cruise actuators are the same, its the throttle cables that vary.
