Author Topic: Air con Compressor  (Read 1490 times)
mhwest
Air con Compressor
« on: 18 April 2007, 15:05:44 »
Question on clutch activation on copmpressor, not regassed have to fit new high pressure pipe set , because of this does the car system not activate the clutch till gassed  ( clutch works ok ) no power at plug.
Re: Air con Compressor
« Reply #1 on: 18 April 2007, 15:26:40 »
The air conditioning system has a pressure valve that disables the compressor clutch to protect it if the system pressure is below a certain level.
I hope that answers your question.
mhwest
« Reply #2 on: 18 April 2007, 16:31:10 »
Thanks kevin I thought it was something to do with the system as a safe guard did not think the plug had failed was working ok before. but had to check on this.
