Author Topic: Power steering fluid spurt from resevoir  (Read 2419 times)
« on: 18 April 2007, 21:34:11 »
 :question Noticed "oil" drip today. On inspection it was tinged red. Opened bonnet and when the steering is turned full lock a spray of fluid jets out from the steering resevoir cap (there seems to be some sort of pressure relief hole in the actual cap). I`ve had the motor since December and this is the first time it`s happened. Fluid level is OK. Any ideas on this one chaps.
Re: Power steering fluid spurt from resevoir
« Reply #1 on: 18 April 2007, 21:40:14 »
Overfull maybe?
« Reply #2 on: 18 April 2007, 21:48:45 »
Overfull maybe?
Checked fluid level fortnight back. All ok. Silly question, but would the fluid volume increase due to hot weather leading to a temporary displacement of fluid?
GaryB
  • Stanmore
« Reply #3 on: 18 April 2007, 22:06:02 »
It probably does expand as it gets hotter (it is the same as ATF and on the older autoboxes where you could check the level, you had to do it hot ;)), but I do not know the specifice for the 'meega power steering.
GB
Markjay
  • London
« Reply #4 on: 18 April 2007, 23:07:48 »
Overfull maybe?
Been driving two Omegas over 8 years through hot weathers, never experienced anything like that... sorry, but it does not sound normal to me... maybe someone else can advise what might cause this.
Alas, no more Omegas....
nemesis_v6
  • tiverton devon
« Reply #5 on: 19 April 2007, 02:34:33 »
im new to omegas only had mine about a month so not to sure were the pipes are but on my calibra i had same proplam and it was the powersteering pipes vibrating together next to the rad down on the chassis this might help just thought i would mention it
